engine bay rinse
Old Jun 3, 2010 | 07:51 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
engine bay rinse
I want to go to the car wash and use the high pressure washer to spray down my engine. Is there anything that ABSOLUTELY cannot get wet? I know not to spray the alternator, battery, anywhere near relays ect. Will I be fine doing this? its a stock 88 L98.
Old Jun 3, 2010 | 07:54 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: engine bay rinse
im wanting to know this too.
Old Jun 3, 2010 | 08:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm carbed - and I sprayed everything except directly at the carb with degreaser, waited 5 minutes, and hosed it all with the hi pressure - just don't spray directly into the air intake/filter no matter what induction, and you should be fine - I even sprayed all over the top of the intake to get it cleaned up (being careful to not spray the air filter/carb). You'll learn real quick if a spark wire is bad or if your dist cap has a crack if/when it gets wet - but those should dry out within a 1/2 hour - if you haven't had any issues in rain, you shouldn't have any issues at all.
Old Jun 3, 2010 | 08:51 PM
Chainshot's Avatar
Car: ►1989 IROC-Z≡ ◄
Engine: ►5.7 TPI◄
Transmission: Original Owner
I would not spray water near the dist. (best to cover it with a bag and tape it up) same for the alternator. Also don't spray near relays, or other electrical items.
An old detailing trick...mix Armor All 50/50 with distilled water and using an empty spray bottle. Spray down your engine compartment - hoses, plastic, etc...
Old Jun 6, 2010 | 03:00 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i know this sounds crazy...but have it running while your doing it..car might run a little funny for like an hour..just gas to 80 a couple times and u should be good
Mikey
Old Jun 6, 2010 | 03:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
hose down cap n wires with WD-40 once your done if it runs funny.
USe to do that with my motorcycle but would leave it running as water often got in bad places, but still running kept it going, just have to be careful that you don't shock a hot engine with cold water, take it slow.
Old Jun 7, 2010 | 07:30 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Originally Posted by Gumby
take it slow.
lmao..agreed
let us know what happens
Mikey
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
