different color engine bay
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
i was wondering if there are people out there that have different color engine bays than the body color on there car.
i would appreciate some pics to get an idea of how it looks.
for those that have the different colors, do you like it? or no.(explain please)
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: different color engine bay
I think thats a dead giveaway of a cheap paintjob. Why do you think most people dont change the color of their car when they repaint? Its expensive to do it right.
Engine: V8 305 TPI
true true, and to do it right is time consuming if you want to change the color, because you need to take the engine out.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
blacking out the engine bay is done quite often too, so are other low maintenance colors for various race applications
my engine bay is satin black.
Car: 1991 GTA,1951 ford f1 pickup
Axle/Gears: 3.42 10-bolt
that's a good example you got there 86TA and anyone with half a brain can see that is a serious set-up too
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Wow! Any more pics on that? That is how I want my engine bay to look when my 355 gets done! Beautiful! Any info on the air cleaner to hood ducting?
Car: 1997 z28
Engine: lt1
Transmission: t56
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
whats with the rad overflow? iv never seen one of those before!
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Wow, subscribing. Great thread.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
My car is all black so a different color engine compartment would look dumb. On my 79 TA the car was maroon with a black engine compartment and I was happy with it.
Car: 86 Trans Am
what brand stb is that? i have a carbed engine and cant find a good tubular stb. thanks!
Car: 86 Trans Am
[QUOTE=//<86TA>\\;4745531]thats the most up to date pic i have. The air pan is custom made, i designed it and a friend fabbed it up for me at work. Its 16ga aluminum. Mounts to a scoop try mount that bolts under the carb. It was an attempt to force the engine to breath from the cowl and not the engine bay.
QUOTE]
Any interest in you or your friend creating one for me? I have the VFN 4 inch cowl hood on my 91 and looking for something similiar.
QUOTE]
Car: 86 Trans Am
[quote=Camrs89;4745824]
sorry, but no. I can't weld aluminum, and he is out of work hurt right now.
besides, it was made to fit my car, engine setup, hood ect. Unless it was for the exact same setup, there would be little chance of it fitting properly.
QUOTE]
QUOTE]
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
