Tinted Windows?
Old Jan 17, 2011 | 05:58 PM
Guest
Guest
Posts: n/a
Tinted Windows?
Someone before had horrible tint on there i took it off now and have it off but most the glass from previous owner has scratches.
I bought new tint that's a nice clean black and isn't to dark
Should i put it on.
Old Jan 18, 2011 | 08:18 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Tinted Windows?
You might want to see if the scratches can be buffed out/removed and if that is more cost effective than glass replacement.
Generally, the question to ask yourself is "Can I afford to replace the scratched glass and when".
If you don't plan on changing the glass for a few years then go ahead and tint.
If you think you will replace the glass within the next year then hold off.
Old Jan 18, 2011 | 12:28 PM
Roachjr's Avatar
Re: Tinted Windows?
Scratches usually aren't too notcieable without tint on them. But once tint is put on it'll really show off the scratches. If it's really bad I would leave it alone untill you got new glass..
Old Jan 18, 2011 | 01:33 PM
Andrew1320's Avatar
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
Re: Tinted Windows?
I had the same problem with my old* car. We tinted the windows hoping the scratches would be hidden....boy was I wrong, It looked worse tinted. So we went to a pull-a-part junkyard and just got new windows and believe this, they had brand new tint and not a scratch in it. We paid like 50.00 a window.
Old Jan 18, 2011 | 04:24 PM
Guest
Guest
Posts: n/a
Re: Tinted Windows?
Ok So Your saying hold off untili get some new glass. And tint from before stained it how would i buff the glass. Thanks guys great info.
Old Jan 18, 2011 | 04:40 PM
Stephen's Avatar
Car: 87 GTA
Re: Tinted Windows?
Is it scratches or leftover adhesive from the tint?
Old Jan 18, 2011 | 05:15 PM
Guest
Guest
Posts: n/a
Re: Tinted Windows?
looks like sratches from the tint also when look at the window give that mirror rainbow look? but has spots all over them.
I tried my hardest by hand to buff them but nothing. And also it left a print on the back of my window with a smiley face. Someone's disgusting tint job. That will show up when it's really cold.
Old Jan 19, 2011 | 12:19 PM
Roachjr's Avatar
Re: Tinted Windows?
I would spray the window down with Windex and take a new sharp razor blade over the entire window to make sure all the glue is gone. I think i've even seen some guys take really fine steel wool over the glass to clean it too. I've done that on the outside of a windshield before to help remove bugs and it didn't scratch.
But if your glass is already scratched you don't have anything to lose anyway lol
Old Jan 19, 2011 | 01:49 PM
Guest
Guest
Posts: n/a
Re: Tinted Windows?
i already took all the glue off but the wool had some gave it a try worked a little bit but not much.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
