HOW TO ANODIZE ALL YOUR OWN TPI PARTS.
Old Oct 11, 2001 | 08:17 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Why pay someone when you can do it yourself. This is HOW to do it.
Supplies Needed:
The first thing to do is to get the following things together: First on the list is the most expensive item: a 6 to 12 volt battery charger. They run from $45.00 to $110.00 depending on model, functions, etc.(The next item, though not that expensive, will take some effort to find: battery electrolyte, a.k.a. sulfuric acid. This should be available at a battery wholesaler for about $2.00/gal. To make the negative ground, you will need some aluminum ground wire and aluminum-foil. The wire can be found at an electronics store for about $35/spool, and you should have the foil in the kitchen. If you happen to be out of foil, you can pick up some more at the store when you go to buy the last item for this project. No super-special chemicals or solutions necessary to make the colors; just plain-old fabric dye. (Something like Rit dye, for about $5.00.) Rit offers something like 30-40 different colors, so you have quite a number of choices for what color you want your parts to be. An optional item is nitric acid: about $25.00/2.5 L. (This is used to clean parts prior to anodizing, but there are some cheaper alternatives. See end notes.) This is available at chemical supply stores. Should you not be able to find any, you can try to get on the good side of the high school science teacher. He may help you out since you only need a few ounces.
Safety Precautions:
There are a few precautions I want to go over to help keep you from blowing up the house or trashing the garage. First of all,
do not mix or store your anodizing solution in a glass container. Something could happen to make it break, and most households are not equipped to deal with that kind of spill. You also don't want to knock over the container, so a stable,
rubber bucket makes a good choice. You will also need to be certain that the part you want to color will fit in the container
without sticking out of the solution, and without touching the negative ground in the bottom of the container. Any acid that you
don't use, keep in what it came in, or an old plastic bottle, like a bleach bottle. You can also store your used solution this way for doing more parts later. (Make sure that there is absolutely no bleach left in the bottle. Acid and bleach make chlorine gas. Very bad. Don't breath. Poisonous.) Safety also applies to the nitric acid, but in a different way. It is imperative that you label and keep track of this stuff, as it is a stronger acid than sulfuric, and more dangerous. The breakage/spill problem is not as likely since you won't have that much around. (Unless you bought more than a few ounces from the chem store.) The last note about the acids is to mix properly when adding acid and water. Always pour acid into water, never the other way, and do so slowly, being sure to mix in well. There is a reaction taking place and it releases a lot of energy. During the anodizing process, you will be running electricity through a weak acid solution. This creates hydrogen (just like charging a battery) which is very flammable. This stuff burns at the speed of thought when ignited, so do be careful. (Read as Remember the Hindenburg?) Make certain that there is some way to ventilate the project area, and DO NOT let any sources of ignition (NO SMOKING) near the project area. Other precautions you should take include safety glasses, rubber gloves, and maybe some sort of drop sheet under the area.
Preparations:
One of the most essential things you need to do in order to get even color over the whole part is to be sure that the part is
absolutely clean. You want it free of all contaminates, from dirt to the oils in your skin. This is where the nitric acid and some
rubber gloves will help. A solution of 1-2 ounces of nitric acid in a gallon of distilled water will allow you to clean the surface in preparation for the anodizing. Aluminum oxidizes very quickly when exposed to air, so the easiest way to keep it clean is to clean it just before you are ready to start working on the piece. (You should rinse the part with distilled water before you put it in the next acid solution.) Other options are carburetor or brakes cleaners, or other similar degreasers. Soap and water will work also, or cleaners like Simple Green. These are cheaper, a nitric acid wash is the best. (You decide, it's your money.) =) Make your negative ground with the aluminum wire and foil. Shape the end of the wire into a paddle shape and cover the round part with the foil. What you want to do is create a flat, round shape to sit on the bottom of the bucket, with a lead that comes up out of the bucket. You will clip the battery charger's negative lead to the wire that comes out of the bucket. When you are ready to start, you will want to mix up your immersion solution. In your rubber bucket, combine the sulfuric acid and water to come up with a solution that is about 30% water. (1 part water to 2 parts acid.) Place the paddle in the bucket and attach the negative lead. Then attach the positive lead to the part, making it an anode, and immerse it in the solution. (Remember that thetwo leads the paddle (cathode), and the part (anode) should not touch.) This is the best time to turn on the charger: once the part begins to fizz, leave it in there for about 10-15 minutes. After about this time the part should no longer conduct electricity. (You can also use an ohmmeter to check conductivity, but this is not needed.) Turn off and disconnect everything, and rinse the part in cold water. Don't use hot water! You'll find out why in the next section.
A couple of notes:
I have read some other procedures that say it is important that the copper lead from the charger does not enter the acid
solution. The article says nothing about this, and shows a picture with the lead right in there. It may take some trial and error to find out if this is a problem. It wouldn't be a bad idea to get some scrap aluminum and play with it before you start anodizing your parts. You can check out the above, as well as pick the colors you like best. If you test out some colors,
you'll also learn just how long or short you need to work with the color solution.
Color:
So now it doesn't conduct electricity, and is ready for color. It's been rinsed and waits eagerly to change to a new look. Don't
wait too long to do the color, due to that oxidizing thing again. You want to mix up a strong solution of dye and water, in a
container that can be heated. The solution needs to be at low heat, such as on the stove, so bread and cake pans work well.
Again, you need something that will fit the whole part, but it's okay if it touches the bottom this time. I would recommend
turning parts every few minutes just to make sure that you get all-over color. Inform your mom or wife that the pan can (and
will be) washed out. It is important that the heat be low enough. If the solution gets too hot, you will seal the surface, and it will no longer take any color. (See, told you to rinse it in cold water!) Leave it in the dye until the part is slightly darker than you want it. The next step is to seal the surface of the metal in clean, boiling water. This will leech a bit of color from it, thus the slightly darker color in the previous step.
End Notes:
Also, this process is for aluminum. I don't know how, or if, it will work on other metals. (I doubt it.) Anodizing only works well on rock metal like bar or sheet stock, as opposed to castings. If it was forged or machined, it should have the density to take
color through this process.
Something to consider when looking for a charger, is how many amperes it puts out. Without getting into any mumbo-jumbo,
anodizing relies on 10 to 40 amperes per square foot. For small brackets and such, this is no problem. The larger parts
however, may need the higher levels of amperes. The other note about part size, has to do with how long you leave it in the
solution. Above it said 10-15 minutes, but that is for a smaller part. The larger parts may not only need higher amperes, but
more time as well. I would recommend an ohmmeter, but again, I have one already.
So there you have it. Quick, fairly easy, and not too expensive. If you don't have the charger, then your first anodizing session
could cost as much as sending your parts out to be done. But, then you can do it again for much less. Or do your buddies stuff.
Or talk them into chipping in on a setup for all of you to use. We all know ways to help make things cheaper.
And the stupid statement required to cover myself... If you try this and something gets messed up, or someone gets hurt, you are on your own. Deal with it, you can't blame it on anyone else.
Old Oct 11, 2001 | 08:34 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Great article! Thanks man!!!
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Oct 11, 2001 | 09:35 PM
JPrevost's Avatar
Car: 91 Red Sled
Contact Dirk and make this into a tech article. Very useful information. Would be kind of cool to see a carb edelbrock air gap intake anodized red or something funky .
, Jon (350 TBI!)
91 Red My website
Old Oct 11, 2001 | 10:23 PM
Snuffit's Avatar
Car: 89 formula
Transmission: t5, soon to be t56
ok you say in the topic that its for tpi parts but at the end its not for casting. will it work on the tpi parts? i thought they were cast aluminum? it would look killer if i could make my whole polished tpi a shiny light blue (to match my paint)
Snuffit
Old Oct 11, 2001 | 11:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
n/m
[This message has been edited by deadbird (edited October 12, 2001).]
Old Oct 11, 2001 | 11:41 PM
deadbird's Avatar
Engine: TPI 305/ v6
n/m
Old Oct 12, 2001 | 04:58 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
well not to flame, but that will KINDA work.. but u will get ****ty results. for the past 6 years i played paintball. .and u could either get your gun anodized ro it came with it.. and some people already tried this "home made ano job" and if u dont get everything exact its ruined/ there is no way to get the stuff off. well u can get it off.. but u can only anodize alum*and only certian TYPES of alum* 3 or 4 times before the metal is.. well not solid if that makes sence. well its really not THAT expensive. it jst depends on what u want done. ie single color, 2 colors, 3 colors, Fades, patters, slpash , acid wash.. ect. prices are usually like $140 for 12 peices *1 color* or like $200 for a 3 color fade. looks for white wolf airsmithing *cheao* or PKselective *but they are VERY $$$* on the net. when i get home, ill post some links and send out some emails to see if people to it.
[This message has been edited by aziroc (edited October 12, 2001).]
Old Oct 12, 2001 | 06:04 AM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
thats an awesome article but it sounds like an accident waiting to happen for me. haha. i can see it now; "Florida Man Blows Up Neighborhood Trying To Home-Anodize Car Parts"
Old Oct 12, 2001 | 12:45 PM
mcconahay37's Avatar
Do you have any pictures of parts you have anodized? That way, we can see the results.
The Sumbitch is Broken
82 Camaro:350, Erson cam, ported heads,Comp Cams 1.6:1 rocker arms, Edelbrock Performer RPM intake, Holley 600cfm,
TH350 tranny with 2500 stall, Eibach Pro Kit, SLP 1 3/4" headers with 3" Flowmaster exhaust
Old Oct 12, 2001 | 03:42 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Just a word of warning... 10-40 amps and a bunch of acid, electrolytes? Read his article carefully, if you **** up bad, 10-40 amperes will manke damn sure you don't get to try again. .015 amps can KILL a person.
Be careful people!
Dave
Old Oct 12, 2001 | 05:25 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
It works good if You polish the parts 1st.
When I worked at a plating place we use to anodize a number of aircraft parts. but had a real ano. machine. In the sence Its the same thing.
I do stress BE CAREFULL IF YOU TRY THIS. Like said befor.
Stary on small stuff. stock scrap runners etc. I havent done any tpi parts but It would work. I may pick up some spair runners or DO a stock intake that is collecting dust in the basement. It will have to be sanded 1st. Just like polishing.
Old Oct 17, 2001 | 03:42 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
<font face="Verdana, Arial" size="2">Originally posted by aziroc:
well not to flame, but that will KINDA work.. but u will get ****ty results. for the past 6 years i played paintball. .and u could either get your gun anodized ro it came with it.. and some people already tried this "home made ano job" and if u dont get everything exact its ruined/ there is no way to get the stuff off. well u can get it off.. but u can only anodize alum*and only certian TYPES of alum* 3 or 4 times before the metal is.. well not solid if that makes sence. well its really not THAT expensive. it jst depends on what u want done. ie single color, 2 colors, 3 colors, Fades, patters, slpash , acid wash.. ect. prices are usually like $140 for 12 peices *1 color* or like $200 for a 3 color fade. looks for white wolf airsmithing *cheao* or PKselective *but they are VERY $$$* on the net. when i get home, ill post some links and send out some emails to see if people to it. [This message has been edited by aziroc (edited October 12, 2001).]</font>
FUnny cuz I put the exact same thig up as a tech article and got this responce
posted 07-08-2001 02:28 pm
I work at AI Industries in Redwood City, Ca. We are one of the better and more respected surface finishing companies on the West coast. You're pretty creative to think of something like that. Do you have any prior experience in the anodization field? Really, that was a good follow through on the process. I hope everyone who tries this remembers to use gloves. Acid does wierd thing to your skin. Oh yeah, you can't anodize steel, or copper, etc. It won't work. Also, you made a good point reguarding castings. It comes out looking really ****ty. I noticed you're from Milipitas, have you heard of the company I work for? We do a lot of **** for Applied Materials.
Old Oct 17, 2001 | 06:21 PM
UVA3rdGen's Avatar
Cruz'N Bruz'R you should give ohms law a little bit more credit. Sure at 1,000,000 volts a little amps can do wonders, but at 12 volts its going to take a lot to even throw your arm back. But it is enough to generate some nice sparks, or burn some thin wires red hot which is pretty scary near anything volatile. Still, I could not agree more, be careful caustic acid is some nasty stuff (PH of 0!)
My 1LE Brothers IROC
SCCA 1LE
89 IROC
She is not the fastest thing in a straight line but she sure will stick in the turns.
Hawaiian Orchid X-SCCA showroom stock 2-time national/ 1 time regional (not with me driving) champ 1LE 92 Z-28 and the family 89 IROC
Old Oct 17, 2001 | 06:53 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Ohm's Law 4 Free!
Next lesson: Power factor and the messed up things 1,000,000 volts can do to living things.
LOL
Caspar
Jun 19, 2016 11:19 PM
ydnar417
Sep 23, 2015 05:57 AM
gixxer92
Sep 1, 2015 04:32 PM
someone972
Aug 30, 2015 12:52 AM
Sanjay
Aug 12, 2015 03:41 PM
