4th gen coolant bottle need pics of battery tray
Old May 17, 2011 | 02:24 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I did the swap on my 85 last year before I found a unmolested shell and is super clean. So i want to do the mod again but the hole i cut last time was crazy huge. I really dont want to do that again. Ive read all the threads on here but in all of them no one posts a pic of just the hole in the tray. If you have a pic of the hole then with the bottle in it would be appreciated. Thanks
Old May 17, 2011 | 07:09 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: 4th gen coolant bottle need pics of battery tray
https://www.thirdgen.org/forums/auto...en-washer.html
pics of my swap
Old May 18, 2011 | 05:34 AM
6SIX6's Avatar
Car: 89 IROC
thank for the pics but I need one of the passenger side as mine will be on that side. The hole I did for mine was way longer than that. Maybe i screwed up tho.
in the second pic it looks like you raised the battery tray. What did you use??
Anyone else have pics
Old May 18, 2011 | 07:47 AM
Pillsbry10's Avatar
That is drivers side.. Just used a flat piece of metal to raise tray a bit
Old May 18, 2011 | 09:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The hole needed for the reservoir to fit down in the tray is teardrop shaped. I made a cardboard template to fit the coolant reservoir snugly for Pills car then transferred it to some sheetmetal. That was then trimmed to fit the battery tray area. It's kind of temporary as his tray was rotted out and, since his was modded to work on the opposite side, it didn't sit properly in the tray area as well.
Old May 18, 2011 | 09:23 PM
Pillsbry10's Avatar
and it and the washer bottle are probably one of my more fav mods
Old May 19, 2011 | 05:20 AM
6SIX6's Avatar
Car: 89 IROC
I just hacked mine again LOL it fits just got the move the fender brace
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
