My paint project has begun!!!!
Old Sep 13, 2011 | 04:56 PM
  #51
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: My paint project has begun!!!!
Originally Posted by 85projectZ28
spray the gloss and there will be orange peel. wet sand it with 1500 grit then 2000 grit. now I have a nice smooth gloss all over. (hmmm... maybe no buff at this point...Im not too sure...) Now spray the clearcoat all over and buff it to a mirror finish. Of course I gotta let the paint cure between these steps.
I guess that is what was throwing me.
Generally speaking, base coat is a matte finish and not really able to be buffed out to a high gloss like a single stage acrylic. The shine/gloss is in the (good) clear coat, not the underlying color layer. Base color goes on fairly thin and lays quite flat most of the time, leaving you with a smooth color coat (no orange peel) to apply clear without sanding.
Also, spraying clear over a buffed out finish will net you a gain of your clear coat peeling off in sheets after a period of time. Even 15-2000 grit is somewhat light for the clear to be able to 'grip'. I have never used anything above 600 when it comes time to lay color, base, or clear. Generally, no sanding is needed between base and clear as long as you are in your time window for applying.
I am only hobby painter, the above is only my opinion and everyone has a bit different technique.
The best idea, though, is to pick a line (brand) of paint and use it as a system, primer/sealer to clear for best comparability and results.
Old Sep 13, 2011 | 06:42 PM
  #52
panhead201's Avatar
Car: 1989TA WS6
Engine: 305tbi being modified
Transmission: 4l60e
Axle/Gears: .73
Thats the only way I've ever done it.I've mixed ditzler paint with DuPont primer and had terrible results once.The entire paint job peeled off the car in sheets.It started out as small air bubbles under the paint and within one day,we could peel the paint job off the car.It was an expensive mistake.panhead201
Old Sep 13, 2011 | 10:02 PM
  #53
deadbird's Avatar
Engine: TPI 305/ v6
compatibility, not comparability... poor typing on my part
Old Sep 14, 2011 | 12:39 AM
  #54
panhead201's Avatar
Car: 1989TA WS6
Transmission: 4l60e
Axle/Gears: .73
My typing skills and grammatical skills will not recieve any awards in the foreseeable future.All that aside,I've owned restoration shops and bodywork and paint made up the vast majority of the time spent.There are paints that are made to be base coats(require a clear or tinted clear coat)to be applied over it.Then there are paints that are a one part system.Not counting primer,actifier,flexerizer,metalflake,etc,etc,over it.Just like the paint you got from your rattlecan.For me,I'll use .600 grit sandpaper to knock down a primer that was also meant to be a filler.Dupont 30S for example.After that I find 600 way too coarse to not be seen and felt on a paint job.I grew up pre acrylic painting and spirit based laquer was the paint of choice.Clear laquer would be appliedover it for depth,life span,whatever.We'd use 1200,1500,2000 until the final coat was buffed out by machine.Then,depending on the customer,car paint job,billable hours,whatever,we'd buff it by hand.19 or 20 coats of lquer would not be uncommon,one coat being your first pass from left to right,your second pass being your return,left to right.It was an ungodly ammount of work,and I have the spots on my chest x-rays to thank for it.I dont use anything but acrylics anymore,unlss its an enamel.I hope your paint job turns out great,your hood stripes look really good!panhead201
Old Dec 8, 2011 | 07:33 PM
  #55
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
awesome job. paint looks real good.
Old Apr 30, 2012 | 11:37 PM
  #56
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Its been a while but despite the fact that Ive been busy with everyday life, I have been pretty hard at it when good weather permits. Im not fully done but heres a teaser pic of what Ive done so far...
Engine bay was completely sanded, cleaned, primered, painted and clear coated.
I will post more pics when Im fully done. It should be about another month or so...
Old Apr 30, 2012 | 11:41 PM
  #57
Engine: 5.7 LSX
One more, heres a pic of how the engine bay looks now...
Old May 1, 2012 | 08:43 AM
  #58
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Looks good bud!! Keep up the good work
Old May 20, 2012 | 09:11 AM
  #59
Engine: 5.7 LSX
All Done!!! Well, with the paint job anyway... The car is still far from done as you will see, but just one day shy of the one year mark that I started this thread and project and I finally finished the body! Enjoy these pics and let me know what you think. Keep in mind, I had no prior experience in paint or body work. Here they are...
Old May 20, 2012 | 09:12 AM
  #60
Engine: 5.7 LSX
Heres the engine bay...
And one last shot from the side...
So, Id like to hear anyones thoughts. I hope you like it as much as I do!
Old May 20, 2012 | 09:19 AM
  #61
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
That came out really well! a color sand and buff will make that clear shine like glass
Old May 20, 2012 | 10:06 AM
  #62
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Yes progress. Now in between you can color sand and buff it out. It has come a long way.
Old May 20, 2012 | 10:13 AM
  #63
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
Looks great! Wetsand that and buff it out and it will be very sharp!
Old May 20, 2012 | 10:51 AM
  #64
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Needs a major sand and buff. Be careful when cutting out that sag in the drivers door.
Old May 20, 2012 | 11:58 AM
  #65
LivinLarge's Avatar
Paint scheme looks incredible. Love the black and silver with the red touches! What wheels are you going to run?
Old May 20, 2012 | 01:41 PM
  #66
Engine: 5.7 LSX
18" x 8" Chrome IROC Replicas in the front and 18" x either 10" or 11" in the rear, I gotta figure out what fits.
Old May 20, 2012 | 09:34 PM
  #67
Engine: 5.7 LSX
So the consensus is positive, yet unanimous that I need to wet sand and buff it. Any tips on how to best accomplish this? Like... Technique, what grit, how much water and what kind of soap if any, what sanding pattern, and for the buff.... What material of bonnet, what best compound to use, what size, what speed, etc. Any help would be great! Thanks!
Old May 22, 2012 | 05:15 AM
  #68
Amythyst's Avatar
Car: 1986 Trans-Am
Engine: 305 5.0 TPI
Transmission: 700 R4
Axle/Gears: 2.73 posi
I love the way you did your hood. It looks really good.
Old Jun 4, 2012 | 07:08 AM
  #69
geoff jaymes's Avatar
Car: 1987 Pontiac Trans Am
Engine: LB9 305 TPI
Axle/Gears: Limited Slip, possibly 2.73
Beautiful. Just Beautiful. This color scheme is one of the best custom looks I've seen on a thirdgen. REALLY DIGGING IT!! I'm in the same boat as your right now with my TA, except not quite as far, still early stages.
Old Jun 4, 2012 | 03:05 PM
  #70
LivinLarge's Avatar
Where did you get all of the emblems for the exterior?
Old Jun 5, 2012 | 12:48 PM
  #71
Engine: 5.7 LSX
Front bumper emblem was from summit racing, all other emblems are from hawks thirdgen parts, the front lights were from eBay, rear lights were from Klearz.
Old Jun 5, 2012 | 12:50 PM
  #72
Engine: 5.7 LSX
Oops! Sorry, the 388 hood sticker was made by a friend of mine. And thanks for all the compliments everybody! I love it too and am very proud of it!
Old Jan 13, 2014 | 07:39 AM
  #73
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
love this paint!
Old Jan 13, 2014 | 06:07 PM
  #74
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
Originally Posted by scarbucket
love this paint!
Really?
Old Jan 14, 2014 | 01:00 PM
  #75
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Originally Posted by visitor
Really?
Why wouldn't he??
Old Jan 15, 2014 | 07:06 AM
  #76
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Yeah I think the paint looks really good I might be coping and something similar for for my car except I wouldn't do this over around the bottom I just is this black clear around and silver racing stripes with the red pinstripe
Old Feb 9, 2019 | 04:10 PM
  #77
Engine: 5.7 LSX
It's been quite a while! I haven't done much of anything lately. But, I have been having fun with the customization in Forza Motorsports 4. Here's more or less how I would love my car to look like when all is said and done.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
