tips on removing tar spots
Old Oct 21, 2001 | 02:40 PM
rusty12's Avatar
Anyone no an easy way to remove bug & tar marks. I've tried those "Bug & Tar" removers in stores but i have to clean the car about five times until the marks come off. Does dishwashing detergant work? Thanks for any help.
'92 Camaro RS,V6
JVC kd-sx770 head unit & speakers
Old Oct 21, 2001 | 02:41 PM
OldBlue's Avatar
theres a product called goo-gone that works pretty good. you can find it at most of the grocery stores.
Old Oct 21, 2001 | 03:26 PM
Roshambo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by rusty12:
Does dishwashing detergant work? </font>
Dont use dishwashing liquid. It removes the wax from your car, and thats really bad for the paint! I havent had much luck with the bug and tar removers either, the best thing Ive found is some good car wash, and lots of elbow grease.
-Roshambo
-Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, No Cat, 3" exhaust from Y-pipe back, MSD Super Coil, Accel 8mm wires, L98 Aluminum Heads, Ported and Polished Plenum, Siamesed Intake, Aluminum Driveshaft, Edelbrock 3 point Strut Tower Brace
Old Oct 21, 2001 | 04:09 PM
Blue502's Avatar
Put some thinner or solvent on an old rag and carefully wipe off the tar. Then wash and rewax the spot right away. I use this method not only on my show cars, but also on my dump trucks which get asphalt all over them. Never hurt the paint on any of my vehicles over the last 24 years (and the paintjob on my '86 is a 12K one), but remember, don't rub hard, you are trying to disolve the tar not scrub it off.
I imagine that WD-40 would work as well, but might need a bit more time to cut through the tar. I also use WD-40 to remove adhesive residue from my windows.
IROCnRoll
'86 Camaro Sport Coupe and '88 IROC
Old Oct 22, 2001 | 03:52 AM
sheet outta luck's Avatar
the use of bug&tar removers will strip the wax also
if the tar wont come off with a regular car wash,use a clay bar or just rub wax into the area, the wax will remove just about anything.
thats also useful when removing emblems that are attached with double sided tape; the wax strips the leftover sticky crap off
Old Oct 25, 2001 | 01:59 AM
TBIfly's Avatar
WD-40 does work,use it without the precision tube (red straw) use a tight-knit cloth...terry towels work but tend to leave fuzzies and deteriorate more quickly
Old Oct 25, 2001 | 02:47 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I have used WD-40, but it takes off wax. I would only use it if I was planning on waxing soon. I don't know if it hurts paint though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
Jlanz55
Sep 6, 2015 07:28 PM
