Weird 4x6 projector headlights
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I was just on google images searching for headlights and i came across this one: http://www.bigrigchromeshop.com/Merc...HDLITB/UP31375 . Every 4x6 headlight for our cars that say "PROJECTOR" are said to be fake. If i can get some opinions on this one. It does look pretty weird but i cant tell if this is a crap projector or semi real one. If this one is junk then ill probably end up building my own real projectors. Thanks
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Weird 4x6 projector headlights
I see "Sylvania Halogen Bulb" which makes me believe it isn't a HID true projector. Just a halogen bulb like the Firebirds fog lights one is.
Engine: 5.0 LB9 TPI
Yea i read that to. The problem with the ebay projectors is its just like a magnify glass for the projector. I mean i was wondering if you pop an hid light in there if its better than the ebay ones. It really caught my eye as a semi real projector.
Car: '91 TA vert
Engine: turboLSx
It's obviously not HID but there is a shroud around the projector lens. Could be a good bowl design or not, who knows. I'd like to see someone buy them and find out. Only problem is if you plan on running an HID retrofit kit it will place the capsule in a different location than intended which could be real bad for light output.
Engine: 5.0 LB9 TPI
Car: '91 TA vert
Engine: turboLSx
Kind of. The light is designed (hopefully) to throw light in a specific location. If you change where the bulb mounts (the origin of the light) the light being thrown out won't go in the intended direction. It may not even be noticeable, but you won't know unless you try it.
Engine: 5.0 LB9 TPI
Yea i hear you. Only problem stopping me from buying it now is how it looks. I have a set of fake ebay lights and they actually have a nice look to them i really dont know how this would look and its 100 for a pair. Any photoshop guys interested in making a pic with these lights on a red camaro??
Engine: 5.0 LB9 TPI
Heres another image if this is better http://miami-star.com/media/catalog/...us02-2227l.jpg . Just to ask, for our factory lights they make aftermarket h4 conversion lights that look like the factory ones right? If they do, how would the light project on that if you put an HID system in there?
Engine: 5.0 LB9 TPI
Well heres some cool news, i called the shop up and he told me these arent like the junk ebay lights. He says there is a cut off inside and it will work good with hid's. Only problem is once the little LED lights burn out they cant be replaced. They also offer the same kind of style in high beams, heres the link: http://www.bigrigchromeshop.com/Merc...HDLITB/UP31376
Car: '91 TA vert
Engine: turboLSx
Horrible. And just because there is a cutoff doesn't mean these new lights will be good for HIDs either. Unless the guy you talked to has done it and has pictures, I'd be more inclined to think he's just trying to sell them to you. Maybe I'm just a cynic though.
Engine: 5.0 LB9 TPI
Im going by his word. It would be nice to see some installed pics. I wouldnt mind buying them if after they werent like he said and i can get a full refund. Being stuck with crappy 100 dollar lights would suck, at least the ebay ones i never used were 20. Im going to call them back up and see if they have any pictures installed and if any with hids
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
They are $93.70 EACH not a pair! For $400 for a full set of high/low I want real projectors.
Engine: 5.0 LB9 TPI
Engine: 5.0 LB9 TPI
They do look pretty nice, but yea the LED's kill it. If they were 93.70 a pair id have a set. If anyone does take the chance in buying one or two, post some pics with it installed and opinions on it
Car: 1987 Trans Am
Engine: LQ9/L92
i've been looking for a projector with cutoff (mandatory for me) for my bird for some time to do an HID conversion to. These seem like the best option so far, but it doesnt look like they make one for the bird lights, booooo. I'd give up high beams for a solid low beam
Engine: 5.0 LB9 TPI
Car: 1987 Trans Am
Engine: LQ9/L92
the issue is not the wiring, but that the birds use a different size & style of housing than the camaros. gotta keep searching (and hunting for the money that's not in my wallet
) Joined: Nov 2002
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Just because the title says "projection" doesnt mean they're projectors!As the link you have on post #9 uses the same wording, except for hi Vs low & those are obviously not projection of any kind.
Even at $93 each that would be too cheap for real projectors.These use a 9000 series bulb.Factory/OEM (true to the bone/real McCoy/whatever you wanna call them) projectors are either D1S or D2S type.Anything else is a halogen (meaning reflector, not projector) lighting.The so called bowl (if there really is one) is designed for halogen bulbs, not HID lamps.The cutoff means nothing in terms of performance.Its merely to prevent blinding oncoming traffic.
Ever notice the cheap/fake projector sellers never have images of they're "projectors" displaying light on the road.Its mostly head on shots of some bright *** light.Even a flashlight will look bright in photos.Dont be fooled by that.Ask the seller if they have any images how the lamp "projectecs" the light on the road.
Save your money, even if they were 93/pair.
Car: GTA
Car: '91 TA vert
Engine: turboLSx
Out of everyone on this board I would've presumed you'd know that not all projectors are HID. Maybe I'm not reading your post correctly or something but it sounds like you're saying it has to be HID to be a projector, which is untrue. Please correct me if I'm reading your post wrong.
Car: '91 TA vert
Engine: turboLSx
Hey thanks for clarifying. Seeing as how you clearly wrote these "aren't projection of any kind" and "true projectors use d1s/d2s" I can't believe how I would've been confused! /sarcasm
What a ****ing awesome contribution to the thread.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Better clarification is in the link..click on it!
"those are obviously not projection of any kind" is in reference to that.
"Factory/OEM (true to the bone/real McCoy/whatever you wanna call them) projectors are either D1S or D2S type".
A genuine projector is always going to be HID.The only genuine HID lamps are either D1 or D2 designation, so a "true" HID projector will either use D1 or D2 type lamps.Thats how they were designed from the get-go,All other HID lamps (H4/7/9,9005/6,etc) are modified D1/D2's to accept halogen, (i.e (H4/7/9,9005/6,etc) sockets.Halogen projectors are reverse engineering.Basically, an HID designed projector modified for halogen bulbs.Halogen projectors never perform like HID units, even when an HID lamp is used inplace of the halogen bulb.So i stand by my remark "true projectors are either D1S or D2S type".Hologen projectors are not true (genuine) projectors, even with an HID upgrade.
Still confused?Go to hidplanet.com & read up.Thats where i got my HID education.Ive said what i said above till i was blue in the face, but people here either just want "the look" or buy a pseudo projector/HID set-up in hopes of finding honest to goodness proj/HID results.You get what you pay for.
]rant[
]rant[
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Hey no problem! And thank YOU for not reading, and asking the same question! You've been AWESOME
I'll include a pic of my true hid/projector set-up to hopefully ease the waddage of your panties.
Car: '91 TA vert
Engine: turboLSx
While I admit my response was a bit crass your ignorance of what was written still remains. Plus, you illustrated exactly 84 1LE's point of useless photographs.Good job!
Car: '91 TA vert
Engine: turboLSx
I'm not arguing that these rebased HIDs are good products. I know all about HIDs with a 900x. They're bandaids to get the right output. Which is exactly what I said earlier in this thread. That a retro kit with a 9003 base will not put the lights focal point in the same location and could produce undesirable results.
]rant[
]rant[
Engine: 5.0 LB9 TPI
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not a dedicated HID projector,never said not a projector, but this argument will go on forever.
You did say that, you clearly said that ALL true projectors are D1S or D2S, which these are not. Dedicated HID projects, yes, 100% agreed, they are ALL D1S or D2S, however there are lots of Halogen projectors out there and they definitely don't use a D1S or D2S bulb.
Car: 1988 Camaro Rs
Engine: LH0 V6
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
For camaro1122, this is the best I have. This was a while back.
Car: '91 TA vert
Engine: turboLSx
You're not helping your case here. Seriously though, I'm sure your projector setup works great. I'm retro'ing some now to finally ditch my re-based h4s. can you take some REAL shots of the cutoff and such? Mucho appreciate.
Oh, Okay.
Engine: 5.0 LB9 TPI
Since this seems to be a thread where everyone knows lights lol i have a question, might not be the brightest but here i go. For those ebay fake projector lights that everyone uses for a retrofit, if your good with metal fab work could you make like a shroud but only cover the area where the said to be projector piece is? Meaning the inside of those "projectors" have a glass circle and its held up by the side metal stands, where the H4 light goes in its basically open which is where the light reflects from. If you were to cover the area open where the bulb goes would that make a some what better said to be projector? I know my wording sucks but its kind of hard to describe.
Car: '91 TA vert
Engine: turboLSx
Problem with this is 99% of properly designed projects put the bulb/light source in a reflector bowl that is specifically built so that as much light as possible is focused through the projector lens. All these ebay lights are nothing more than a standard h4 conversion assembly with a random projector lense tossed in there. If you mounted a shroud block half the light output, you'd do just that. Block half the light output. It wouldn't end up going through the projector lens. If that makes any sense?
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Ouch low blow lol. I would love to but the iroc is out of commission right now. I can tell you this; I've never gotten flashed, no attention from the popo, everyone compliments, and I can actually SEE the road. Its been a pain for me to drive my formula lately I can't see **** at night.
Engine: 5.0 LB9 TPI
Yea thats what i was asking. I was an idea that popped in my head. It really does suck that the only true projector lights for our car is 1000 unless you make your own. I guess when you first get your car those ebay lights seem like an amazing buy since there so cheap lol. My buddy has an 08 mustang and since he didnt want to spend money on aftermarket lights he just threw in some hids. His have a little umbrella looking thing and the light bulb fits up to that, just like the ebay ones. Just to ask, does the light really go wack? It seems like all the older cars from like 05 and down use a hologen bulb with the umbrella thing, isnt all of those setups blinding as well?
Car: '91 TA vert
Engine: turboLSx
True blue projector HID retrofit kits cost so much because of the R&D and labor associated with this. Companies have never wanted to give away their product (well, most) so it'll probably still be awhile until we see inexpensive setups.
Engine: 5.0 LB9 TPI
So if i buy an ebay umbrella set they would be junk if i put an hid kit in them? If you were just wanting a cheap hid light set, what setup would you go with for thirdgen camaros??
Car: '91 TA vert
Engine: turboLSx
Having run the cheap DDM kit and H4 conversion headlights for awhile now I would say save your pennies for actual HID style projectors from a reputable source. They light output is impressive even with a crappy HID retro and that's why so many people love them, because they're so much better than Halogens. However they glare and throw light everywhere. I've been ordering my components from hidplanet for awhile now. I'm trying to fit a bixenon morimoto mini in a firebird headlight bucket. If It were a camaro I'd run any of those projectors since you guys have much more room behind.
Engine: 5.0 LB9 TPI
I want to save up for a nice retrofit set, but i also want to drive at night. Im close to finishing my engine and tranny build, so id like to get on the road at night and show her off after a year of just sitting in the driveway. I dont know how i keep finding these lights lol but what do you think of these? http://norcalmr2.com/pegasusjr/ Do they look custom made? I emailed him asking about him, info's at the bottom
Car: GTA
They make for good housings to mount a true projector into, but that is about all they are good for.
Engine: 5.0 LB9 TPI
I mean my fab skills are a total fail, so id be buying it from someone willing to make it on here WHEN i get the money because there not cheap. Just to ask about the H4 bulb they provide with the set, does that blind everyone to?
Car: GTA
And judging by the video of the Pegasus (not Jr.) the light output is like only 30ft (or something like that).
Engine: Cammed 6.0L LSX
I'm bringing this back from the dead because I have a question and I see a lot of knowledgeable posters who know what they're talking about.
If I were to tackle a true retro fit projector set up with a D1 or D2 projector, does it matter how far back in the fake H4 housing the projector sits? I was gonna pick up the aftermarket sealed beam housings since they're plastic not glass so I can cut off the back ends and fiberglass in the projectors but didn't know if there's a mathematical sweet spot on where to put the projector or a certain angle it needs to be set at?
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
I am ordering a set for myself soon.
http://www.tlg-store.com/product_p/6010003.htm
OH MY!! Nevermind that, i totaly missed that from the beginning. Yep ill def get real projectors if im basically paying in the same range!!!!
