How to remove B12 stain under gastank ?
Old Oct 27, 2001 | 03:16 PM
WaynesRS's Avatar
Well when I put some of this in my car ,I used a funnel and tried not to get it on the car , well it ran like a waterfall down the side of my car below the gas cap .Is there anyway I can get this off without re-painting ? And by the way , its a white car , dont know if that mattes . Thanx , Wayne
Old Oct 27, 2001 | 05:50 PM
WaynesRS's Avatar
anyone know how ?
Old Oct 28, 2001 | 12:08 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Try using buffing compound. It might buff it out of the paint. If it does work, make sure you polish the spot and then wax it again.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Oct 28, 2001 | 04:42 PM
WaynesRS's Avatar
Thanx Ward .
Old Oct 29, 2001 | 10:06 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Wash the area thoroughly with a grease cutting soap like Dawn. Than use a rubbing compound (clear coat compound if you have a clear coat) or some other type of paint scrubbing compound and try rubbing out it by hand with that. You can try maybe using a cleaner wax first as it is the least abrassive method of removing stains and scratches. When you are all done getting the stain out (or have given up on it), be sure to polish and wax any areas that you used the harsh soap and/or rubbing compounds on. Those harsh chemicals will strip all of the wax and some of the top layer of paint (or clearcoat) off, leaving the finish unprotected.....
Good Luck....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 31, 2001 | 09:51 AM
Chris Luongo's Avatar
If you get desperate, sometimes Bleche-Wite whitewall tire cleaner will get stains out of white paint.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
