How To Keep Brake Light Blackouts On??
Old Oct 30, 2001 | 11:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've had blackouts on for about a year. And it seems every 3or4 months I have to take them off and reapply new double sided thick type tape, the velcro kind. I think what happens is water gets in and loosens some of the adhesiveness. I use rubbing alcohol to clean the surface before applying it so there shouldn't be dirt affecting it. Anyone have any tips.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 30, 2001 | 11:34 PM
Gib_Sandwich's Avatar
If I was you I would go down to the junkyard and buy a set of tail lights from another car and then drill a hole and use a pop rivet gun
Then if you screw up you only have little holes and can make another go at it, if not, well at least your tail lights are fine
Nobody ever got cancer from smoking tires!
gibsandwich@hotmail.com
Get ICQ Page My ICQ
ICQ # 18562788
1982 Z28 Camaro
305ci LG4, Muncie 4-Speed, Holley Carburettor (CFM Unknown), 2.5" Stainless steel exhaust all the way through.
Fibreglass hood.
Boston 4x6" CX7e 2-ways, 6x9" Nippon America (no-name?) 3-ways
Other stuff I haven't figured out yet.
Old Oct 31, 2001 | 04:13 AM
sheet outta luck's Avatar
i had the same problem with a firebird i once owned, they fell off the first night i put them on after i did a burnout...but anyhow,
the reason they are probably falling off is because you might not have heated the double sided tape before application.
just heat the side of the tape thats going on the taillamp (after you pull the paper strip thing) with a blowdryer RIGHT BEFORE you apply them to the car
that was the tip I overlooked and after i tried it, they never fell off again
Old Oct 31, 2001 | 11:57 AM
Car: 99 Formula
Axle/Gears: 342
Cool, I'll try the blower dryer next time I reapply them.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Frozer!!!
Jan 19, 2024 04:55 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
