how to get stickers off exterior, please help
Old Sep 15, 2011 | 11:30 AM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
just got another camaro the other night. it has a newer paint job but the kid i got it from put these stickers on it how can i take them off with out damaging the paint job. please help. i plan on keeping this car all black and throwing some ss craigers on it and a bbc motor this winter. something i wont feel embarrassed driving around town in like the green camaro........ what was i thinkg lolol
Old Sep 15, 2011 | 11:48 AM
FooFighters92's Avatar
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
Re: how to get stickers off exterior, please help
Are they car vinyl? Or are they like..stickers?
Old Sep 15, 2011 | 11:54 AM
89fbrestor's Avatar
he said vinyls
Old Sep 15, 2011 | 11:56 AM
jpossibul's Avatar
Car: 1985 Black and Gold Trans Am
Engine: 305 Tuned Port Injection
Transmission: T5 Borg Warner Manual 5-speed
Axle/Gears: 3.08
A heat gun would help tremendously.
Old Sep 15, 2011 | 11:59 AM
Engine: 305 TBI
^ Yes. Get a heat gun...a hair dryer would work and get something to get underneath like a razor blade or something...obviously you have to be extremely careful. And if it's vinyl it should just peel right off. Do it slowly and carefully. The only thing that would suck is if those stripes have been on there long enough the paint will be newer and blacker underneath.
Old Sep 15, 2011 | 12:01 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
A heat gun and a lot of care? Maybe some very hot water soaked rags left over the stickers? Something to soften up the adhesive, of course. Hell, with a black car you might be able to park it outside on a hot sunny day and just peel the stickers off.
You do know your losing about 3-5 hp a sticker right? HA
89fbrestor's Avatar
he got the car the end of last summer so about a year they have been on there i would assume
Old Sep 15, 2011 | 12:19 PM
89fbrestor's Avatar
You do know your losing about 3-5 hp a sticker right? HA[/quote]
lolol well its a good thing i painted the green camaro then cuz ya this black one does seem a little slow lol
Old Sep 15, 2011 | 01:31 PM
devianb's Avatar
Heat gun works best for removing the sticker, but the residue is still kind of difficult to remove. I use something like goo off and a soft rag. Hot water can work too, but it has to be scalding hot and takes a bit longer due to the water cooling down.
Old Sep 15, 2011 | 01:37 PM
89fbrestor's Avatar
what about wd-40
Old Sep 15, 2011 | 08:13 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
You need to be extremely cautios with the heat gun, you can mess up your paint if you stay in one spot to long. If you use a razor blade sand the ends with a piece of 220 grit paper, I know this sound wierd but if you look at a razor blade under a microscope you will see imperfections in the edge, this cleans it up and makes it smooth. We used this method for removing decals from police cars that came into the shop for repair. Leaving it out in the sun for a day should soften them up, try and lift an edge with the blade and grab hold and pull slow, it just wmay come off.
Old Sep 15, 2011 | 08:51 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Leave the hairdryer in your sisters room. Use this.
Old Sep 16, 2011 | 06:05 AM
89fbrestor's Avatar
great tips guys thanks so much. that strip off wheel looks interesting... i wounder if it would burn threw the clear if you stay in one spot for to long?
Old Sep 16, 2011 | 06:37 AM
cliff1970's Avatar
Car: iroc z
yes it will. you have to keep moving on paint.
Old Sep 16, 2011 | 08:36 AM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
Post 12 & 14 are the only way to go. WD 40 and goo be gone will finish the job. Hopefully the paint was fully cured before the vinyl was added.
Old Sep 18, 2011 | 03:38 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
heat gun, peel it off and use 3M adhesive remover from any auto parts store, should take not even 5 minutes
Old Sep 18, 2011 | 04:21 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Looks like he had a nice paint job put on it. Sweet looking ride. Black is so hard to keep clean. But it sure looks nice when it is clean!
Old Sep 18, 2011 | 04:39 PM
89fbrestor's Avatar
thanks guys, ya i just picked up a motor for it tonight it has a 305 in it but a 350 with a super charger might be a little funner
Attached Thumbnails how to get stickers off exterior, please help-charger.jpg   how to get stickers off exterior, please help-motor.jpg
Old Sep 18, 2011 | 04:48 PM
hemicudakidd's Avatar
Car: 1970 Plymouth Hemi Cuda
Engine: 426 Hemi
Transmission: A833 4 Speed
Axle/Gears: Dana 60
Hey, I'm a detailer so sometimes i have to take things like vinyl graphics off vans when they are being sold on.
I use a heat gun and if you get the edge of the sticker, the rest should come with it slowly and carfully. NEVER usa a razor blade. If you slip, jump or sneeze, there goes your paint job.
Then for what glue or adhesive is left, either go to an auto parts store and buy some tar remover or just use gasoline or parrafin. It dues the same job.
Do it like that, and you'll find they come off easily and leave no marks
starliner
Feb 9, 2016 08:18 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
1992Z28!
Nov 19, 2015 07:33 AM
Nervous2
Oct 8, 2015 10:53 PM
