LED Strips
Old Dec 13, 2011 | 10:25 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
LED Strips
I just happened to stumble on these. I don't like to post ebay links due to the time sensitive nature of auctions.
You LED freaks will find a use for these, I'm sure.
http://www.ebay.com/itm/LED-Strip-Co...item3f0bea27ea
Old Dec 18, 2011 | 01:36 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: LED Strips
They sell strips like this at any autozone or O'Reillys. They are around $20 for about two feet of the stuff. I actually had some of this stuff (in blue) hung up under my dashboard in my intrepid because the dome lights went out and I am lazy. The stuff is pretty bright and you can get it in assorted colors. Do you have any questions on the stuff or are you just showing off what you found?
Old Dec 18, 2011 | 09:03 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: LED Strips
I took the O'Reillys stuff and mounted it to the bottom of the doors triggered by the door jamb switch. Open the door and the ground is illuminated. My car didn't come with footwell light which I may soon be adding as well.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
