Rust Spots On Car
Old Feb 9, 2012 | 06:06 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Rust Spots On Car
I recently bought this car and it has rust spots on various places mostly the roof.
What steps should i take in removing the rust?
Old Feb 9, 2012 | 06:15 PM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Re: Rust Spots On Car
The way I would handle it is to remove the rust through sanding or grinding the rust way with (~80 grit sand paper and a wire wheel), treating the spot with a phosphoric acid, then rinse (something like diluted Krud Kutter), to add a zinc coating to prevent further rust, and then coat with a 2k epoxy primer, build primer and paint.
Basicly, get the rust cleaned up and wipe with some phosphoric acid, rinse, and paint. Don't leave it with spray can primer (even the rustoleum sealer primer) that'll absorb water - and it'll start rusting again.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Exxon Limited
Aug 9, 2015 08:13 PM
