Painting Calipers
Old Nov 8, 2001 | 05:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Painting Calipers
Anyone with experience, especailly on car? If so, what was the preparation and product that you used?
JamesC
Old Nov 9, 2001 | 12:38 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I painted mine on the car. Basically I just cleaned them, masked the surrounding areas, and sprayed them with high-temp aluminum paint. I don't have any pics, but they look pretty sweet.
Old Nov 9, 2001 | 01:02 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yep, I used a wire brush to get all of the rust and crap off of them and sanded them down a bit in some spots to get em somewhat smooth. Then I cleaned them with some brake cleaner and sprayed them with about three coats of 1800* Duplicolor engine paint (semi-gloss black).
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 12, 2001 | 06:20 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
If you want to do it for looks, paint them any color that you want to. But I paint mine flat, or satin black, because it transfers heat better. As for preperation, you'll be fine making sure that there is no oil, or grease on them. Surface rust is no big deal, infact it makes the paint stick on better. You can use high temp paint, but you don't really need to. I use plain rustoleum on everything, except headers. Engines, mufflers, pipes, never had a problem.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
