decal residue help
Old Apr 15, 2012 | 09:00 AM
HotRodLarry's Avatar
Car: '83 Z28
decal residue help
I'm in the process of replacing the stripes on my '83 Z28. What can I use to get rid of the leftover residue from the decals?
Old Apr 15, 2012 | 09:09 AM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: decal residue help
Try products like Goo Gone and lot of elbow grease.
Old Apr 15, 2012 | 10:13 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I've had luck with WD-40
Old May 11, 2012 | 08:28 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Yes Goo Gone and NOT Goof Off. Goof Off is lighter fluid.
Old May 11, 2012 | 08:41 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
3M Stripe Off/Eraser Wheel.
Removes stripes or rub strip adhesives & do not affect the paint. Just keep it moving because obviously if you sit still with it long enough then heat will build & the resulting heat could affect your paint.
http://www.youtube.com/watch?v=HHKN5_UfDik
Old May 11, 2012 | 09:04 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Hey BlackenedBird, forgot about the 3M products. I've seen 3M General Purpose Adhesive Cleaner in the stores but never tried it myself. Is that the same stuff you're talking about?
Old May 11, 2012 | 09:15 AM
Car: GTA
Dunno what the "3M General Purpose Adhesive Cleaner" but the wheel I mentioned is actual "rubber" wheel that you chuck into your standard drill & use. (watch the youtube video yet?).
I used one on a 5 yr old black 1997 Tahoe (factory paint) when I pulled off the factory rub strips along the side. The paint was perfect afterwards, didn't harm the paint & there was zero evidence that they were ever there. I suppose if it has been like a red & had lots of sun exposure, then what was under the strips woulda been brighter red than the sun faded stuff around it, but that has nothing to do with the wheel itself.
Old May 11, 2012 | 10:23 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
You need "Pre Cleaner" (it's used to remove all types of residue before and after you paint). That's what we use at the body shop. Plus...if you go shooting WD-40 all over your hood...and need to repaint it down the road. Good luck. WD-40 causes fish eyes.
You can pick pre cleaner up at any body shop supply store.
Old May 11, 2012 | 07:48 PM
red rock's Avatar
Car: 1987 iroc
Wouldn't you prep a part before you paint it? I haven't had fish eye's since the walleye's i caught last winter.
Old May 11, 2012 | 09:31 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Any silicone product will cause fish-eyes, thats why we prep before paint and use only silicone free products in the detail area
Old May 12, 2012 | 11:35 AM
Engine: 5.7
Yes....you always prep before you paint. But shooting WD-40 all over a hood doesn't help reduce the risk of fisheye's...or silicone contamination. If an area get's contaminated with silicone....it's very very hard to get a descent paint job....doesn't really matter how good you even prep the panel. At that point...the area has been contaminated with silicone and it's "in the air". That's why alot of shop require "body shop safe" products in their shop.
Old May 13, 2012 | 09:16 PM
red rock's Avatar
Car: 1987 iroc
Just mess'n with ya. I've only used wd-40 on small decal residue. Probably a good idea to use the right product for a bigger job.
Hotrodboba400
Dec 10, 2019 07:07 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
pimprs
Sep 10, 2015 03:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
