86 Z how do you take teh third brake light off? And can you leave it off?
Old Nov 14, 2001 | 03:06 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
How do you get it off? If I can't leave it off I have to paint it. Thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 14, 2001 | 07:54 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
You should be able to just remove the two large hex screws on the inside of the glass and it should pop right out. You may need to take the two screws on the top outside off as well but i dont think so. You can leave it off, but only if you want to have two good sized bolt holes in your hatch. Otherwise your either gonna have to replace the hatch, or possibly find some plugs for the holes.
Eric
My 1986 Z2814.59@95.6
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles! no times yet, just got it to start.
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Moderator at: www.generation-3.com
Old Nov 14, 2001 | 08:53 PM
blackZ28's Avatar
im petty sure in some states though u have to have a third brake light. i know here in CT that you have to have one unless your car was made before 1986 but im not sure if thast the law everywhere.
1982 black Z-28:
-350 ci w/edelbrock 600cfm
-T5 Tranny
-4.11 rear end
-Blue Racer performance cam
-Dynomax headers
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
