Rehab for Coolant / Wahser bottles...
Old Jun 13, 2012 | 07:13 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Well, I remember a couple years ago, new ones were plentiful on Ebay...
Now can't seem to find any....
So option 2...
Paint?
I know I would have to clean / scrub with tri sodium phosphate to REALLY clean them... then I was thinking Krylon White (for plastic) and a sealer if needed....
Any other ideas?
Thanks,
Rafael
Old Jun 13, 2012 | 07:17 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Rehab for Coolant / Wahser bottles...
For the coolant tank I would probably just get a new one there are still some on ebay.
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Maybe something useful below:
https://www.thirdgen.org/forums/auto...lant-tank.html
JamesC
Old Jun 13, 2012 | 07:24 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
I just purchased a new coolant tank last year at the dealer for $15ish
Old Jun 13, 2012 | 07:33 AM
JamesC's Avatar
Different years apparently had different sized tanks, both of which are available from the site below:
http://www.hawksthirdgenparts.com/cooling_1.aspx
JamesC
Old Jun 13, 2012 | 07:37 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
If buying new ones is not an option, I have had limited success in using drano crystals to clean out the inside of them.
Be careful ...that crap will burn through your skin if it gets on you. Use heavy gloves
Old Jun 13, 2012 | 12:05 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Here is a washer bottle from Modern Day Muscle, I deal with these guys a lot. Shipping prices to Canada are as good as they get.
http://www.ebay.com/itm/82-87-Camaro...item43b0b2e04a
onthedownlow
Old Jun 13, 2012 | 12:06 PM
58mark's Avatar
wrong one for his car
Old Jun 13, 2012 | 12:15 PM
Engine: 355
Sorry wasn't paying to close attention...I just bought one of these exact bottles for my 84 camaro. The bottle is for 82-87 camaro so I should be okay.
Old Jun 13, 2012 | 12:19 PM
58mark's Avatar
not if you want the washer pump to work, or you would have to mod your car with a pump from an earlier year. in the later years the pump is on the tank itself
Old Jun 13, 2012 | 01:27 PM
JamesC's Avatar
The one that onthedownlow links to appears to be the early style where the washer pump is mounted on the wiper motor (IIRC, 82-87) which should fit his 84 without issue, but not the OP's.
JamesC
Old Jun 13, 2012 | 01:28 PM
58mark's Avatar
yes, that's what I meant to say
Old Jun 15, 2012 | 09:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The most difficult tank to find is the washer bottle,the one that forms around the cruise control unit.I finally found a NOS one on ebay.
Old Jun 15, 2012 | 10:34 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
fourth gen washer, after market billet overflow, options for non-stock builds
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
