how can i go upon prepping these rims.
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
hey all, just picked up set of these z28 rims, for 75 bucks! was a decent deal, or i think so. anyways, i would like to know how to go upon prepping them to paint them up, fixing pitting, ect ect. here are some pics for a reference. all input is greatly appreciated.
COTM Editor
Re: how can i go upon prepping these rims.
You need to remove the old clear coat and paint as a first step. I used this brand stripper from ACE hardware...
Use a old paint can or something metal to pour it into then brush the stripper onto the wheel and watch it bubble up.
You can see how it is bubbling and peeling up. This need to be scrapped off, or brushed off with a heaver bristle brush. Don't use a plastic or sythetic bristle brush. They will melt.
You can smooth out any curb rash, and polish the metal, or brush the metal back to near original finish at this point. If you choose to re-paint the wheels you will want to mask off your tires and choose the color. I used red, for the original color.
I used Duplicolor Wax & Grease remover to remove the still wet paint from the "machined highlight" area of the wheels. This method gave me the cleanest lines.
Used Duplicolor Clear wheel paint, after everything was cleaned and perfect.
I ended up re-doing this particular wheel due to the poor job of removing some the paint from the wheel window. I figured the new paint would cover and smooth that... 5 coats later... no
awesome!! thanks a ton. got one cleaned up pretty decent, still have some paint spots to take off, ill keep ya posted on the progress
