HID kit help?
Old Jul 24, 2013 | 01:29 PM
Caleb_91RS's Avatar
Car: 91 Camaro RS.
Engine: 3.1L V6 :(
HID kit help?
Can anyone tell me why when I turn on my low beams, my high beams also come on but are very dim. I've switched the wiring like I'm suppose to in order to get the right color, but other than that I haven't done anything but plug and play.
Old Jul 24, 2013 | 02:14 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: HID kit help?
I have the same issue in my E36 swap but it doesnt bother me or is really that noticeable for me to worry about it as you cant tell when the lights are on. I would like to fix it tho if there is a way to
Old Jul 24, 2013 | 02:55 PM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
Re: HID kit help?
I would start by replacing the headlight relay.. they should not be lit at all when lows are on..
Old Jul 24, 2013 | 08:12 PM
Psychoz28's Avatar
Car: 1984 Z28 / 2002 Z06
Engine: 350 New Crate / LS6
Transmission: T5 / M12
Axle/Gears: 3.73 / 3.42
Re: HID kit help?
Nah its not the relay!
Look on the Low beam, When the (+) going by the headlamp, it split up and pass thru the high beam, you need to disconnect the 'green' wire to the low beam!
Old Jul 25, 2013 | 08:05 AM
Caleb_91RS's Avatar
Car: 91 Camaro RS.
Engine: 3.1L V6 :(
Re: HID kit help?
So if I disconnect the green wire on both low beams, the HID's will still work?
Old Jul 25, 2013 | 11:34 PM
Psychoz28's Avatar
Re: HID kit help?
Yes, but the best way to know it is to test it yourself! Just disconnect and you will see! But it worked on mine!
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
