help/idea on fixing t-top trim
Car: '89 trans am gta
Engine: 5.7 L 350 TPI
Axle/Gears: not a clue!
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Re: help/idea on fixing t-top trim
This should be it if im not mistaken
http://www.hawksthirdgenparts.com/pr...tic-Style.html
thanks.
my car is an 89, and i think the trim (drip edge) is rubber, not plastic. Don't know for sure or how that makes a difference. I did see a part # for the rubber one, so i'll check them out. Thanks.
next question...any idea on how to take the old ones off and install the new ones?
any one got any pics on how how to replace this part??
Car: 1984 T/A
Engine: LQ4
pull the weatherstripping out of its channel and remove the weatherstripping bracket. its metal. the rail should be held in with double sided tape underneath it.....or thats how mine was. good luck.
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
I just purchased a pair of those in 2010 for my tops. Year one has them (in 2010 they did anyway). the replacements are plastic not rubber anymore.
it looks like Hawks has them in both plastic or rubber.
Not sure which to go with...
as you can see, my car currently has the rubber ones.
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
