Hello
I got my first 3rd gen this winter I am looking to re-paint it. I have painted many muscle cars. I have always took the cars down to bare metal.Then sealed them with epoxy primer then 2k high build primer. Ive seen many people just scuff there original paint up and paint right over that. I am thinking about doing that with my 3rd gen as it doesn't need much body work. Has anyone ever done a "scuff and shoot"? If so how did you go about scuffing the paint? With a da sander or scotch brite pad?
DynoDave43
close
- Join DateAug 2013
- LocationMICHIGAN
- iTrader Positive Feedback100
- iTrader Feedback Score(11)
- Car1988 Trans Am
- EngineL03
- Transmission700R4
- Axle/Gears10 Bolt 2.73 Open
- Liked:923 Times in 701 Posts
Is your '82 a base coat / clear coat car?
I'm no painter, but given the reputation of GM clear coat in the '80s (I worked at a Chevy dealer, and wrote MANY a repair order for the body shop on warranty paint work), I would never leave it under new paint.
I would be sanding the clear coat due to excessive peeling.
if the clear is pealing then the base underneath is bad. I would sand it down to bare metal and epoxy
I don't know if the right term is peeling. I was from down south and sat out side for 10Yrs the sun took its toll on the paint. I think its more of clear coat fade then peeling.
