water stains on windshield
Old May 17, 2014 | 02:12 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Any thoughts of getting water stains off front windsheild? Plenty glass cleaner and washing didn't help. Someone suggested wax
Old May 17, 2014 | 03:51 PM
Joe Tag's Avatar
Re: water stains on windshield
Water and vinegar solution will dissolve hard water deposits, but I don't like the idea of using an acid on my car.
I have seen detail shops use 0000 steel wool to clean windshields, no It doesn't scratch it. But then you're left with little pieces of steel wool that will rust and leave stains wherever it lies.
Clay bars are awesome for cleaning glass sparkling clean with zero drawbacks. It even polished out some fine scratches in mine. IDK how, but I'm not looking a gift horse in the mouth.
Old May 27, 2014 | 11:16 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Could try a dual orbital polished of the Palm sized variety with a polish. Might be worth a try.
Old Jun 10, 2014 | 04:54 PM
camarorokr's Avatar
Car: 1991 Camaro RS
Axle/Gears: GM 10 Bolt 3.42
http://www.autogeek.net/duragloss-nu-glass.html
I've used Duragloss for years and it always does the trick. If your comfortable with a buffer, poor it on the glass, spread it out with the pad and buff as if you were buffing paint (side to side, pad flat on surface). Comes out looking like new every time. Just make sure you mask your weatherstripping with tape about a half inch from the edge of the glass. Once you get the majority of the glass done, remove the tape and do the edges by hand.
Old Jun 10, 2014 | 07:09 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
this is a stuff called Spot Not. takes it off every thing. in just secs.
wash your car like always.. keeping it wet..(the glass) appply to wet glass with sponge wiping glass. give it 30 sec no more.. and spray off
gass is like new...(not joking)
Old Jun 10, 2014 | 08:11 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Duragloss 501.... May be available @ local CarQuest. Its a great chemical cleaner. Works well on removing oxidation off of metal with steel wool.
Old Jun 12, 2014 | 01:27 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
brand new steel wool 0000 with some polish that has light cutting. Don't use old wool as the rust will scratch the glass as the other person said.
Old Jun 13, 2014 | 02:10 AM
83ZZZ28's Avatar
Car: 1983 Z-28.. Owned since 1985
Engine: LG4 (H) Vin Code
Hello CAMAROKR @ Dyess A.F.B. in TX.... What do they use to clean the W/S on the jets ?
Rod
83ZZZ28
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
codeysabatini
Nov 10, 2015 04:07 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
