Wheel Clay Bars
Old Sep 6, 2014 | 10:36 PM
acdcfan37's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Open Diff
Wheel Clay Bars
I have a set of american racing torq thrust II's that are polished aluminium. They are a bit of a pain to keep clean due to brake dust. Has any one ever used clay bar for wheels? And is wheel clay bar any different from normal clay bar?
Old Sep 7, 2014 | 12:11 AM
Irockthedrag's Avatar
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Axle/Gears: 10 bolt torsen diff 3.73
Re: Wheel Clay Bars
I have. Are your rims clear coated or polished aluminum? I restore rims occasionally aswell. The bars are basically the same. The ones we use at work are for buffing cabinets and I even use those for aluminum, paint, etc. works wonders. We actually run the buffer onto the clay so it's in the buffing wheel then polish the surface that were buffing with it. Results are great.
Old Sep 7, 2014 | 10:06 AM
the_hamturdler's Avatar
Re: Wheel Clay Bars
Wheel clay should be the same for paint. Clay comes in different grades, fine being what you'll find at an auto parts store. If those don't work, you can snag some medium online.
An iron-dissolving cleaner will work well on brake dust too. There's a product called Sonax Full Effect, you can watch videos of it on YouTube and its crazy what it can take off without scrubbing. But don't buy that, you can buy meguires DUB wheel cleaner at advance or auto zone for $8 and it does the exact same thing.
If you hate using clay like me, buy an Autoscrub foam pad. It does the same thing as clay but you don't need to endlessly knead it, just rinse.
Old Sep 15, 2014 | 01:38 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Wheel Clay Bars
I have good results from using McGuire's hot rims (they make a formula for coated wheels and one for uncoated wheels) and then following up with Nevr Dull. Mirror finish that resists dust for a good while.
Old Oct 17, 2014 | 06:37 PM
Mike p's Avatar
Re: Wheel Clay Bars
I bought a car with custom aluminum wheels. They're cleared in spots and brushed in others. On two of them there's small white blemishes on the clear coat part. I tried compounding and polishing the blemishes but it didn't work. What could it be from? It's only on a couple spots on the clear coat.
Old Oct 17, 2014 | 09:47 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: Wheel Clay Bars
The white is the aluminum oxidizing under the clear. Only way to get rid of it is to sand it off and re-clear.
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
rudolphschenker
Sep 4, 2015 02:41 AM
