Primed and getting ready for paint
Old Apr 17, 2016 | 07:47 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Shot the body and door jams with 2K primer high build 3 coats. Then black with 600 grit
Tomorrow with shoot the GFX parts
Old Apr 17, 2016 | 08:25 PM
Billgluckman's Avatar
Re: Primed and getting ready for paint
What color?
Old Apr 18, 2016 | 07:37 AM
kfsullivan's Avatar
Car: 1988 Trans Am w/ WS6
Transmission: 5-Speed
Should be a great looking Camaro. Are you painting it yourself in your shop/garage?
If so, please share you air compressor specs and painting set-up. Thanks!
Old Apr 18, 2016 | 09:25 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Wow. Looking good. I always wonder how people keep track of what goes where to put it all back together.
Old Apr 18, 2016 | 10:19 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Stuff usually only goes back together one way. I always find re-assembly easier than disassembly.
Old Apr 18, 2016 | 10:48 AM
LiquidBlue's Avatar
Transmission: MD8
Ha ha. True on the reassembly. I get worried about putting same screw back in same hole. That's a little harder to keep track of. Especially when all of them are out!
Old Apr 18, 2016 | 09:38 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You might consider at least lossening the front and rear bumper mounting bolts so you can pull them apart from the fenders slightly. It will give you at least a little gap. If you fill the gap between the bumper and fender with paint you run the risk of the paint cracking, chipping or flaking at the edges where they met if they ever get moved or flexed.
Old Apr 19, 2016 | 01:18 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
We used many "labeled" zip lock bags to keep track of every little piece.
Old Apr 19, 2016 | 02:57 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
There you go again Tibo. All he has to do is run a q-tip filled with some silicone in the crack
(everyone else ignore that inside joke )
Old Apr 20, 2016 | 09:33 PM
Car: 1988 iroc
Engine: 350 30 over
Color is a surprise. Iam painting it outside in a 10x20 canopy with curtains, I be had great success with this method
Old Apr 20, 2016 | 10:13 PM
LiquidBlue's Avatar
Transmission: MD8
Photos would probably be handy too.
Old May 8, 2016 | 08:23 AM
Updates?
Old May 8, 2016 | 05:55 PM
WTR388's Avatar
Car: 87 Trans Am
Any pics of your set up? I tried it that way once, but I had better results in the garage with a different set up... And I had a bit more room when it came to painting the sides.
Next time I do it will be in a different garage (I moved) or possibly in an actual paint booth at work!
hotrodjames
May 9, 2016 11:52 PM
Streetstuff
Interior Parts Wanted
Apr 29, 2016 07:22 PM
CamaroManBlack
Jul 6, 2004 08:41 AM
