new paint job???
Old Dec 28, 2001 | 08:36 PM
StocRoc's Avatar
new paint job???
On average how much would a really good paint job cost on my 86 Iroc, the body is very clean because it was painted back in 1996. It just has a few surface rust spots but no major body damage. I mean removing all the ground effects and trim and doing it right. Also about how much for a color change? Do they pull the entire engine to do it right???
Old Dec 28, 2001 | 08:54 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Well for a good one, a minimum of 1500. I've seen $12,000 paint jobs where everything is disasembled and painted. But those are on older collector cars. Pulling the engine should be done if you want it done right, but I would just try to mask as best as you can. Its gonna cost alot to pull a motor
Old Dec 28, 2001 | 09:46 PM
Blue502's Avatar
A decent paint job is at least $1000 just for materials. A true show quality job will start somewhere over $5000, and $10,000 isn't uncommon. The most expensive paint job that I'm personally aware of in my area is a candy red '34 Ford with many layered candy flames which I heard ran around $36,000. Of course if you can do it yourself, or have a relative who will do it for you, you can save lots of $$$. You get what you pay for, and while the difference between paintjobs might not be immediately apparent, put two similar cars with a $2000 and a $10,000 paintjob next to each other and it will become obvious.
Hotrodboba400
Dec 10, 2019 07:07 PM
m00n420
Sep 11, 2015 02:39 PM
rsrookie
Sep 5, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
