Coil installation help
Old Aug 26, 2017 | 02:54 AM
Blu_roc's Avatar
I'm doing an Ls swap in my '90 iroc and installed tubular k-member and A arms. I didn't have a coil compression tool so just used a jack to install some new eibach sport line coils. when I installed the springs I lined them up as well as I could to the stops on the bottom perch but both are about a quarter inch away. Will that affect the height or will they settle when I drive next? Thanks for any info
Old Aug 26, 2017 | 01:53 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Coil installation help
I'm not exactly sure what you're describing but they should settle in after a few bumps. I have a UMI K member and mine were similar.
