Ideas on cleaning up my original pulleys
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Car: 1987 IROC 305 TPI with factory a/c
I just recently found a big problem with my intake, so my friend and I decided to do a cam swap, replace the timing chain, balancer and water pump while we were replacing the lower manifold anyway.
I am looking at the water pump pulleys and the crank pulleys and I am noticing they have rust inside them. I am not sure this is the correct forum to ask for help but it kind of is for appearance but also for functionality. Cleaning the v belt valleys in the pulleys would look much nicer but also I hope to have less noise when the engine is operating.
I am not sure which method to use to clean them up. I was thinking maybe a die grinder tool with a wire brush attachment to polish inside the valleys and just paint the actual pulleys themselves. I searched but most people are ask about aftermarket pulleys. Spraying something in there would most likely cause belt slippage or noise.
Engine: 4++,350 & 305 CIs
Re: Ideas on cleaning up my original pulleys
Sandblast them. Reduces belt slippage too.
You can paint V-belt pulleys, but as a general rule, the paint is going to wear off the contact area under the belt. As long as the car is driven often enough the bare steel never really has a chance to rust. Similar to brake rotors in that manner.
Sandblast and use this for paint.
I wish I had access to a sandblaster. I've been throwing the car back together and decided to paint the valve covers and runners and plenum. I really like this high temp VHT engine paint, "Cast Iron".
I probably will run the v belt valleys with sandpaper before putting the belts on.
