WD-40 to Removing Water Stains?
Old Feb 6, 2020 | 11:59 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Well, we have have some in the garage, and all have some sort of water stains on glass going on. Ran across this on the web. if anyone tries it, let us know how well it works please!
Have you ever wondered how something that’s designed for washing can become so dirty? Cleaning water stains off the shower door, walls, and floor can be extremely frustrating and tedious. Not only does the chore require time, but it also demands its fair share of elbow grease. Luckily, WD-40 can be used as a solution. Simply spray down the affected areas at the end of your typical cleaning session. You’ll soon notice that the water stains magically disappear!
Old Feb 6, 2020 | 01:19 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: WD-40 to Removing Water Stains?
I use 0000 steel wool to clean my glass. It doesn't scratch and with a little bit of cleaner it works like a charm.
Old Feb 6, 2020 | 01:59 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
+1 for 000 gauge steel wool on glass, EXCEPT mirrors. Do not use it on mirrors.
Old Feb 6, 2020 | 03:35 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
WD-40 has many handy uses. My favorite one in particular is how nicely it dissolves stubborn adhesives with a little soak time and a wee bit of elbow grease.
+1 here also for using very fine steel wool on glass, but I use it with a warm soapy water mix, and a gentle touch.
Old Feb 6, 2020 | 05:40 PM
jharrison5's Avatar
Car: '87 IROC
Really... I use it on my mirrors all the time and have never had any issues. Is there something I should know lol?
Old Mar 9, 2020 | 04:23 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I have some water spots on my TPI intake and runners. I might give it a try!
Ron U.S.M.C.
Mar 27, 2013 11:43 PM
ES87iroc
Mid-Atlantic Region
Feb 22, 2005 11:09 PM
Dante93GTZ
Feb 22, 2004 12:55 AM
Buck268
Jun 7, 2002 09:51 AM
