tire rotation
Old Jan 25, 2002 | 11:28 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
tire rotation
ive heard that on radial tires that if you say rotate one on the left side thats been run for a while to the right side that the steel belts inside will have been in a certain way from going one direction all the time and then because they now go the other direction, the belt will try to relocate or something and cause tread seperation. is this true? Is it safe to rotate side to side instead of front to back(not that that would make sense)? please help, friend very worried
Old Jan 25, 2002 | 11:40 PM
Joe91Z28's Avatar
The longer you run a tire in one direction, the better the chance will be that the belts will separate once you run them in the opposite direction. I used to cross- rotate mine and they wouldn't last long before doing this.
Old Jan 26, 2002 | 12:24 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Usualy the rubber burns off before you get a chance to rotate.
Old Jan 26, 2002 | 12:53 AM
Jza's Avatar
Jza
To correctly rotate the tire from one side of the car to the the it's necessary to dismount the tire from the rim and turn it around (or actually better to swap with the rim on the other side). That way the tire will still rotate the same direction, just on the other side of the car.
Old Jan 27, 2002 | 11:38 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
is there any way to tell wich way they should go or can he take it to a tire place and have them look?
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
mfp189
Sep 27, 2015 09:25 AM
