ground effect
Old Feb 24, 2002 | 12:17 AM
PimpCamaroRS's Avatar
ground effect
My front ground effect is very cracked so how do i remove it and get a new one. Also some of my side GFX are falling off, how should make them stick back to my car. are they snaped onor glued on or what? thanx
Old Feb 24, 2002 | 08:15 PM
BADZ's Avatar
ON MY 84 THERE IS A BIG PIN IN THE BACK THAT PULLS STRAIGHT UP AFTER YOU PULL THE Z28 EMBLEM OFF AND TAKE OUT 2 SCREWS IN HE FRONT AND A COUPLE OF SCREWS ON THE TOP INSIDE THE DOOR JAM.
Old Feb 24, 2002 | 09:30 PM
DiecastZ28's Avatar
Whoa there buddy calm down. No need to be yelling.
Old Feb 26, 2002 | 05:41 PM
so no body knows?
Old Feb 26, 2002 | 09:10 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
To get the front spoiler off there are about 30 ish bolts that hold it to the nose and 3 on each fender on the bottom. To get the rocker panel ground effects you need to use a flat head screw driver to pry it out. Then tighten up the 2 screws that are behind the emblem, and there are some on top and bottom, and one bolt that is behind the door. You can get the spoiler at www.yearone.com www.classicindustries.com or on ebay.
Old Feb 27, 2002 | 01:20 AM
ya the front looks easy to take off. Its is this long side skirt stuck on the door tha is slightly hanging. It looks glued on but i am not sure. i will try and get some pics to be more clear.
Old Feb 27, 2002 | 12:29 PM
Car: 85 Camaro SC
Engine: V6
There are 5 bolts with these crappy made nuts.You have to take the door panel, arm rest,upper door panel trim off to get to the 3 inner ones and there are 1 on the very front and rear of the door on the inside. The one on the front is a real pita cause you have to sit on your carpet and make your way to the bolt.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
