window tint
Old Mar 18, 2002 | 09:01 PM
LYV18F's Avatar
window tint
anybody have pictures of their camaro with rear and side tinted windows? i really wanna get them all tinted to 5%, but the rents aren't really going for it. they said they would settle for 5% on the back, but something lighter on the sides, as it's illegal in nj. i'd like pictures of 5% on all the windows or maybe like really dark in the back but lighter on the sides...
thanks
Old Mar 18, 2002 | 09:09 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
You will not pass inspection.
Old Mar 18, 2002 | 09:12 PM
Beene's Avatar
I would post a pic but I can't figure out how! So You could go here to see mine, It's an old pic but you get the idea
https://www.thirdgen.org/rides/index...ew&rideid=7340
Old Mar 18, 2002 | 09:14 PM
LYV18F's Avatar
i know i can't pass inspection... for free. i already asked a couple private places, they said i got the tint the day after they passed me...
Old Mar 18, 2002 | 11:17 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
hehe I know some insiders too
Old Mar 18, 2002 | 11:20 PM
when you posting a reply and typeing stuff look down where it says attach file> hit the browse buton and find the pic on you hard drive
Old Mar 19, 2002 | 04:26 AM
82resto's Avatar
i'll have a pic after my car gets back from the body shop....
i have 5% all the way around, and, trust me, it looks so bad ***....
Jon
Old Mar 19, 2002 | 09:17 AM
NXS055's Avatar
check out my back window on my 92 RS it might as well be painted.... the side windows are pretty dark too, but alas they are rolled down... sorry
http://geocities.com/nxs055/1badRS.html
Old Mar 19, 2002 | 09:53 AM
BigMInstalls's Avatar
heres mine...
Old Mar 19, 2002 | 11:40 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Look at that dirty car. 5% all the way around.
Old Mar 19, 2002 | 02:04 PM
1991 RS 305's Avatar
Here's mine, not to dark but looks cool with the t-tops.
Old Mar 19, 2002 | 02:41 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
me and my friends messed up on my tint huge!
what works best to get TINT GLUE off?
Yes the tint was put on the outside of the window, and yes now its off and sticky as a bitch, and yes im seriously pissed off
Old Mar 19, 2002 | 02:46 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Hmm.
Windex, Heat, and a razor blade. That will do it.
Old Mar 19, 2002 | 09:45 PM
Jim's Avatar
Jim
Car: 85 Camaro
Try rubbing alcohol.
Old Mar 20, 2002 | 10:58 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
Tint
Here is mine
Old Mar 20, 2002 | 02:16 PM
LYV18F's Avatar
those all look really nice but it would help me a little better if you could say what percentage tint it is...
thanks
Old Mar 20, 2002 | 02:34 PM
Stroke_This's Avatar
mine
5%..
Old Mar 20, 2002 | 04:40 PM
breathment's Avatar
goto autozone or wallmart, and get some tint remover, it works pretty good.. if not then i think amonia takes off the glue..
Old Mar 20, 2002 | 10:32 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
WHat about Varsol
that seems to be doing the job
.. very slowly thou
Old Mar 21, 2002 | 03:00 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Man I'm telling you a razor blade will help out the most.
Just spray windex (which has ammonia in it, thats why its not window tint safe) to loosen it up some, then scrape with the razor. Thats what I do the cars I detail, and it does not take too long do. Maybe 10 min. a window. Hope that helps.
Old Mar 21, 2002 | 04:29 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
ok ill give it a shot
its my back window
my sides will come off sometime in the future
Old Mar 23, 2002 | 11:23 PM
XxMoLexX's Avatar
easiest and quickest way... use nail polish remover.. but b careful and dont let it get all over the place.. i used it on my windows to get old tint off.. and it left a couple droplets on my sill plate... bleached it sort of.. but worked wonders.. smelled for a while.. but worked.
Old Mar 24, 2002 | 02:03 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Carb cleaner!
Just done this!
In the UK, I used a spray can of carb cleaner! Spray on a rag and wipe glue off. Comes off with one wipe! Have to keep rag sprayed though. I hope you have carb cleaner in the states!!
Andy.
Old Mar 25, 2002 | 01:00 PM
89BlueTA's Avatar
I have used carb cleaner also with no problems, and it worked very well.
Nick
Old Mar 25, 2002 | 03:25 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The easiest and most NON-flamable way is to use an S.O.S. pad. Just make sure you don't let it run outta the soap that comes in it.
I know you're all thinking "yea if you wanna scratch the **** outta the windows", and that's what I thought to. A buddy of mine works in a detail shop and I asked him. The guy I bought the car off of had put tint on just the back window. Obviously it was his first time doing tint 'cause it looked like bubble wrap.
With the rear window defroster, I didn't wanna take the chance of cutting it. He told me to use the S.O.S. pad and I said "OK, but if it screws up my window defroster then you're paying to get it fixed." He said "OK, and I'll buy you new rims for your car."
Unfortunetly nothing bad happened. No free rims.
So if it worked on the inside then it'll certainly work on the outside.
BTW, he uses S.O.S. pads on chrome also.
AJ
Old Mar 25, 2002 | 03:28 PM
Onyxroc87's Avatar
5% all around......including a one piece rear window......and use Acetone...........cheap,and best stuff I've used yet to remove the glue and crap left behind from a tint job gone bad......lol........
Old Mar 25, 2002 | 03:34 PM
AJ_92RS's Avatar
LYV18F,
If you do this yourself DO NOT USE WINDOW CLEANER!!!!
A lot of kits you buy tell you to use window cleaner (Windex, Sparkle, etc.) on the tint to put it on and work out the bubbles. But don't do it unless you want purple, foggy tint.
Use Dawn liquid dish soap. The lotion crap they use keeps the water and tint slick so you can get those little bubbles out.
And if you want to know an easy way to do the back hatch window, take it off and lay it down. Put a blanket or cloth tarp down on your lawn and have at it. I can do the back window in one piece when I use this method.
AJ
Old Mar 25, 2002 | 03:42 PM
AJ_92RS's Avatar
Onyx,
I have to go to the eye doc now and get my eyeballs put back in there sockets!!!
Your car is the SHIZNIT BOY!!!
That's think looks like it just came off the Lamborgini showroom floor.
Is that a repaint? Or did you wetsand it. I can see Jupiter in the frikkin reflection. And I love those rims. I N V U !!!!!
Guess what my new wallpaper is?
AJ
Old Mar 25, 2002 | 06:48 PM
Onyxroc87's Avatar
Thankz for the compliment ............believe it or not my brother in law and I painted that ourselves.....and I haven't gotten to wetsand it yet either ...........that pic was taken at dusk,I loved the way it came out.It's a repaint,as my car was red in a former life.The Torq Thrusts and ascd BB hood set it off.
Old Mar 25, 2002 | 09:59 PM
LYV18F's Avatar
hey guys, i got it done this morning. 5% all around, black onyx. it looks really nice. i got it done at a place about 20 minutes from my house (all you jersey guys - the tint shop in edison, route 1 north). they did a great job. i'll post some pics as soon as i get my hands on my friend's digital camera, and once it rains here so i can use my hose without getting a ticket (my car is really really dirty).
thanks for all your posts
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
