Another Photoshopping favor needed...
I am contemplating getting the Eagle 077's.
I am curious what they would look like on my car.
Id appreciate a sample from anyone who has the talent to do so.
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
2 things that would make this "do-able":
1. a good contrast (red car against a light blue sky..) side shot of your car taken at shin level.
2. pictures of the rims.
I found the rims, and started, but I am unable to put the rims on your car at such an angle. Someone more experienced may be able to, I haven't figured it out.
Good Luck!
Good Luck!
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Another!!! Man you ask to much.
ha! just kidding well I would try it but I am at work. Well for a angle like that you might want to go to and Im not to sure this is the path put, image>render>3d. now select a circle over the rim and just pull it over and it bends the rim to appear that it is at that angle. Just a hint I cound be wrong on how to get there but thats how I do it.
Oh yeah you could also use the lasso to select the rim then right click in the center of the rim and go to transform, streatch, skew... play around with it its easy.
>redbull gives you wings!!!!!
Or just makes you high or something see ----->>>:lala:
ha! just kidding well I would try it but I am at work. Well for a angle like that you might want to go to and Im not to sure this is the path put, image>render>3d. now select a circle over the rim and just pull it over and it bends the rim to appear that it is at that angle. Just a hint I cound be wrong on how to get there but thats how I do it. Oh yeah you could also use the lasso to select the rim then right click in the center of the rim and go to transform, streatch, skew... play around with it its easy.
duke_mushroom
Oct 9, 2001 10:54 PM
