farfromstock
Old Mar 25, 2002 | 08:14 PM
83procamaro's Avatar
farfromstock
I like that orange color.....mine is manderine copper..i put some blue pear in the clearcoat...i dont recomend that!
Old Mar 25, 2002 | 09:30 PM
86Street's Avatar
is that your car....that is a nice car and i like the paint...just tell me what it has and all the goodies
Old Mar 25, 2002 | 09:55 PM
1982chevycamaroz28's Avatar
yea i checked his homepage and it looks like its all his. lucky sucker.
Old Mar 25, 2002 | 10:33 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Looks sweet, but the flames are weird. It looks as if they start off as orange flames, but then, turn to blue, sorta like an optical illusion. Kinda hard to explain, maybe someone knows what I'm talking about.
Old Mar 25, 2002 | 10:48 PM
jawzforlife1's Avatar
i like the flame trick. Mabey we can get the "masked magician" to explain it???
Old Mar 26, 2002 | 12:30 AM
XxMoLexX's Avatar
yea it looks kool.. but whne u lookt at it u can tell it was jus a template used for each of the "licks" of flame.. repetitive.. but not over done.. not bad
i like
Old Mar 26, 2002 | 06:41 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I bet inside on that camaro.
Old Mar 27, 2002 | 01:36 AM
83T/A_Dave's Avatar
MetalliCamaroRS, yeah I was thinking the same thing, those flames are trippy, but still very cool
Old Mar 27, 2002 | 11:31 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
what size rims and tires are those?
Old Mar 27, 2002 | 06:54 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
the illusion is a tesselation type pattern. Looks bad as hell. very well coordinated with good used of complimentary colors.
Old Mar 27, 2002 | 08:49 PM
Thanks for the complements everyone........Ok...first paint your car a solid color..for instance - manderin copper, then mask off your first set of flames and fill in the INSIDE of the flames with tape....then the blue flames you tape the outside of the flames off, no template, and airbrush in you choice of color...pinstipe everything ....enjoy! This took about 12 coats of clear (3gallons) and you cant feel ANY tape edge. You get good at wet sanding, that is for sure.
The car has a 377 small block making 650 hp. Going to the track next month, but it used to run 11.06 @ 124 with 530 hp. OH yeah, i DO drive it on the street, but not much. :rockon:
here is more pics and the dyno sheet....thats my brothers 68Http://www.streetsourcemag.com/Profile.asp?ProfileID=8883 ....hmm..dont know if that worked?
