Paint Problem!!!
Old Apr 12, 2002 | 02:45 PM
Camaro1991RS's Avatar
Paint Problem!!!
I decided to paint my headlamp pockets black, like the Z28's. I masked around the area and put 5 coats of semi gloss on. Turned out great, except I got some small black spots on the front bumper. The car has original paint and was wondering what would be the best way to get the black spots off.
Old Apr 12, 2002 | 03:51 PM
Kaps's Avatar
goof off might work, but dont leave it on too long and wash the spot right after, thats how my friend got paint splatters off the Fireturd, worked well. USE CAUTION, expecially if has clear coat
Old Apr 12, 2002 | 05:34 PM
Paky's Avatar
I dont think goof off would work, it only works on latex based paints, you might try buffing out the spots, good luck
Old Apr 12, 2002 | 05:35 PM
Paky's Avatar
I meant will NOT work
Old Apr 12, 2002 | 05:55 PM
89blackbird's Avatar
If the black paint is only a day or so old get a clean white cloth like an old t-shirt and whip it off with some mineral spirits.Then wax.
Old Apr 12, 2002 | 08:32 PM
Kaps's Avatar
Worked pretty nice for my friend, I wouldnt try mineral spirits, at least not straight up, there is another type of paint remover, cant remember the name, it contains mineral spirits, but not like straight up, its in home depot or lowes in the paint section, go there and ask someone. Good luck
Old Apr 12, 2002 | 08:56 PM
Mineral Spirits will not hurt your paint if it is removed in a fairly short time.Just use it on a rag to rub off the black paint.It will take wax off. Beware of thinners with additives. Some will take the clear coat off. If your not sure put alittle on a rag and rub it on the bottom of a rocker panel underneath the car. It will clean the road film off and will not hurt the paint. Don't just pour it on the nose or something. Hell I use it to take off tar and sap.
Old Apr 12, 2002 | 09:35 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
blue magic will get em off, what we used to use when i painted for overspray that leaked under the paper this is juts one place that sells it http://www.autobarn.net/ch200.html
Old Apr 12, 2002 | 11:31 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I think claybars are supposed to work on overspray....
Old Apr 15, 2002 | 12:08 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I did the same thing once...talk about Another think you can use is WD40. Spray it on a rag & use to wipe them off. But, always remember to use more WD40 compared to more rubbing force. Afterwards, I would recommend using some wax to cleanup the paint. Good luck!
Old Apr 15, 2002 | 03:15 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Clay bars are terriffic for gettin over spray off. For some reason, there were a few red specks on my car when I bought it, prolly someone touching up another car... anyway, the clay bar got rid of it no problem!
Old Apr 18, 2002 | 01:13 PM
Ok guys, Its been over a week since the overspray has been on, I've had an infection in my knee, so I haven't been able to do any work on it. I got some Rubbing Compound, will that take the overspray off, or should I sand it with some 2000 grit paper and wax it instead.
Old Apr 18, 2002 | 02:15 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
I say wet sand with extreamly fine sand paper and then polish it after wards you will not notice any black over spray.
Street Lethal
Apr 30, 2019 12:14 PM
neekolzun
Aug 24, 2015 04:59 PM
Wife'sCar
Aug 22, 2015 01:46 PM
g.l.mos
Aug 22, 2015 12:02 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
