Just got done waxing, have ?'s
Old Apr 13, 2002 | 08:09 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Ive got lots of swirl marks from the buffer i used, the pad was clean, and its not a super high speed buffer, it's made by makita, anway ive got lots of swirl marks that you can see from every angle, should i do a 2nd coat by hand to remove those marks, or is there somthing else i should do first, thanks !
91Z
Old Apr 13, 2002 | 08:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd say take a clay bar to it, then Meguiar's Step 1 Cleaner Wax. Gets nice results.
HAD SWIRL MARKS
Old Apr 13, 2002 | 09:35 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I buffed my car before.....I thought it was suppose to take out swirl marks?
Old Apr 13, 2002 | 10:04 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Some wax brands have abrasives in them which cause the swirl marks in your clear coat. Thats why I like mothers its clean doesnt break my bank and doesnt leave swirl marks.
Old Apr 13, 2002 | 11:26 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I thought you needed a slight abrasive to remove swirl marks?
Old Apr 13, 2002 | 11:57 PM
Rice Eliminator's Avatar
Let me see if I can try to clear a few things up. True swirl marks are caused by buffing the paint with an abrasive "cleaner," such as rubbing compound, used to help remove scratches, water stains, etc. To remove these swirls, polish or a specific "swirl remover" can be used to restore the paint to a nice, smooth shine. Once this is done, the car would be given a coat or two of wax to protect the finish from the elements. Note that polish and wax are not the same thing; polish removes small imperfections and "shines" the paint, while wax protects it. That's why on older/imperfect paint, the only way to get the best results is to follow the 4 steps: wash, clean, polish, wax. Just don't use paint cleaning or polishing products more often than is reasonable, since they do remove paint (if only a tiny amount) in order to do their job.
Not a pro here, just speaking from some experience.
Old Apr 13, 2002 | 11:59 PM
Another thing: when waxing, I suggest using a real carnauba wax (pure wax), not the cleaner/waxes which do have abrasives in them as someone above stated. Take the time to do a good job, and you should be really happy with the results.
Old Apr 14, 2002 | 12:17 AM
Car: 99 Formula
Axle/Gears: 342
Thanks for the tip, I don't use the cleaner wax that often, but I haven't noticed any paint coming off on the clothes when I do use it, so does that mean it's been safe on the paint so far?
Old Apr 14, 2002 | 01:00 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Originally posted by MetalliCamaroRS
I bought that $20 2600RPM random orbital buffer at WalMart and tried it out today with 3M Swirl Mark remover. Well.. the swirl marks are still there
Do you recomend a certain product? Should I Put it on with my Buffer?
Old Apr 14, 2002 | 10:53 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i agree with Mark A Shields. i had really nasty swirl marks on my car. i used a clay bar and it works awsome.
neilb
Sep 15, 2015 05:06 PM
TheExaminer
Sep 6, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
IROCZTWENTYGR8
May 8, 2001 02:51 AM
