Complete door rehab/resto! I mean COMPLETE!
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I'm sure most of you have experienced those wonderful high points of 3rd gen f-bodys - the doors. Sagging, scraping, rattling, leaking, you name the door ailment, our cars suffer from it.
I've had my car for 17 years now and have attempted hinge pin replacement, window adjustments, striker adjustments, all the easier fixes to try to squelch the din from the doors and nothing solves the issues. I've had the door panels off so many times they disintegrated!
Well, after putting so much time and effort into the rest of the car the door problems were getting harder to put-off and the wife finally said, "FIX IT" after getting a lap full of rain WITH THE WINDOWS UP!
A quick few clicks on Hawk's and Top Down Solutions and I had most of the replacement parts I would need -
New door panels (upgraded to the velour!)
New door panel upper moulding (the plastic part)
Greasable door hinge kits
Power door lock button decals
and Outer door sweeps
I also went to the local parts store for rubberized undercoating, zip-ties, new window motors, acetone, lithium grease, and one more stop to the local body shop supply dealer for the GM 1/4" rivets. I also borrowed a 1/4" rivet gun from the local MAC tools guy (take care of them, they'll return the favor).
After removing the remains of my door panels and vapor barrier I was greeted with this...
Car: 1989 Camaro RS
Engine: ZZ4 350
Upon closer inspection I noticed a number of obvious problems with the OEM attachment points - cracked metal mounting points!!
Car: 1989 Camaro RS
Engine: ZZ4 350
Here is another big source of rattle headaches - a missing limiter (replaced at the factory with a bolt!) and sash roller hanging on by a thread! If anyone has removed the door glass without removing the sash or roller, let me know!
Also notice the crud at the bottom of the door! This is what leads to rust in southern cars...
Car: 1989 Camaro RS
Engine: ZZ4 350
I ground the backs of the rollers to remove the door glass which allowed me to "fix" them as well. I drilled them out, tapped them, and bolted them back on. This will eliminate the slop and allow me to remove them easier in the future.
Car: 1989 Camaro RS
Engine: ZZ4 350
With the doors empty and suddenly 1/3 lighter, it was time to replace the hinges. I spent 4 hours attempting to ground out the passenger-side hinges without removing the door - FORGET IT!!! We may have some talented folks on here but I ain't one of them as I did little more than grind through the paint on the back of the door lip! I finally removed the doors and did the job right!
Car: 1989 Camaro RS
Engine: ZZ4 350
I'm sure most of you are well aware of the greasable hinges sold by TDS and most have seen the article in CHP. I was one of the skeptical ones for years but I will tell you now - problably one of the singlemost dramatic changes to the feel my car came from installing these hinges! This car's body didn't feel this good when brand new! It always felt flexible, but no more. The install is a pain but well worth it!
Car: 1989 Camaro RS
Engine: ZZ4 350
After re-attaching the doors I undercoated the inside of the doors and allowed them to dry and gas-out for 3 hours. I then started the re-assembly of the regulator and glass.
WARNING - DO NOT ATTEMPT REPLACEMENT OF THE WINDOW MOTOR WITHOUT FIRST SECURING THE RETURN SPRING! There are a few posts about this subject so I wont go into detail. Let me just say - I never want to do that job again!
I cleaned the guides with acetone, dried them, then lubed the guides with the lithium grease.
You'll need to remove and reinsert the regulator through the opening at the end of the door, then attach the sash roller (bolted-on as I did), and then guide the rollers onto the sash. Slide the roller onto the rear vertical guide, and then the locator guide located behind the armrest and bolt them in. At this time it's best to attach the outer sash on both doors and attach (and guide) the wiring.
Car: 1989 Camaro RS
Engine: ZZ4 350
Once the regulators have been pop-riveted I made sure all of the window guides were in the original locations, zip-tied any loose wiring that had broken mounts, and tightened everything up. I double-checked the wiring routing, window and door lock operation, and adjustments. At this point I attached the inner door vapor barrier (I bought heavyweight polypropolene) using gasket sealant and installed the new door panels.
Car: 1989 Camaro RS
Engine: ZZ4 350
I'll post completed pictures later today but let me tell you - the difference is amazing! The doors sound fantastic, closing with a firm, solid thump. I'm also rearranging the mids/tweeters locations so I'll have to finish that as well today!
Car: 88' Iroc-Z
Engine: LQ9
very nice, clean it up and submit it as a tech article I've never attempted to repair my doors yet as they just started sounding empty but some of the guys on the board know of a few other trouble spots in the doors to help keep them sturdy.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
as far as i know the pannals have NEVER been off the doors on my GTA. the ones in my v6 bird are getting prety shody from so many removals... i am going to do this same thing to my GTA some time soon. pull the pannals off, new EVERYHTING, put the pannals back on. do it once do it right.
Great writeup. i will be bookmarking this thread for later refference for when i do my own. thanks much
Car: 1989 Camaro RS
Engine: ZZ4 350
I should have gone into more detail about adjusting the glass!
On this picture you will find;
1- The upper position tabs - These 2 felt covered tabs control the position of your glass when rolled-up (inward and outward).
2- Forward positioning adjustment - That large triangle at the front of your doors (sorry the pic didn't have it) allows you to adjust the position (in/out and height) of the front of the door glass.
3- Down limit adjustment - This controls how far down the door glass can go. Most of our cars do not have this any longer and I used a bolt and 2 nuts to make mine work. Had I known this would be an issue on my car I would have made something ahead of time using some kind of urethane (skateboard wheels maybe?
To adjust the door glass start with the front positioning adjustment (#2) and adjust it's position to were the triangle is barely squeezing the weatherstripping when the door is closed. It's perfect when you can just tug a dollar bill from between the triangle and the weatherstripping without much force. The same thing works on the upper tabs (#1) and make sure the force to remove the dollar is uniform around the perimeter of the glass. As for the down limit adjuster (#3), you may not have any adjustment unless you make one! As I said earlier the factory put in this bolt/nut arrangement on my drivers side door so I duplicated it on the passenger side. I adjusted mine so it would bottom-out when the top of the door glass was just inside and even with the inner and outer sweeps.
That seems to have worked on mine pretty well, your results may vary!
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
This is what I am going to have to do. I've tried adjusting my passenger window so many times, but it still sticks outward too much. I've tried the whole range of adjustments and nothing works. I also know about the panels falling apart from so many removals and the missing stops. I hope I have enough time and courage as you did to get this job done right. Is this a daily driver? And how many hours do you think you have in this project?
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Great info, I'll be consulting it in the future when I take on the same project.
If you do submit this as a tech article, can you give more details on some of the procedures, like the installation of the greaseable hinges? You mention it is a real PITA, so there must be some "tricks" you learned along the way...?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
THANK YOU!!! This is excellent! I'd love to see this as a PDF or something as a tech article! maybe give it a bit of time as a thread, to get more questions in!
Any more tips you can provide, like with the greaseable hinges install, would definately be appreciated! I think when I do this, i'm not going to use rivets, but use bolts, and i'd remove that rusted plate, and bead blast it and paint it... Not that anyone would ever see it, but it would bug me
Car: 1989 Camaro RS
Engine: ZZ4 350
I drove it for a couple of hours today and am still stunned at the difference this has made to the enjoyability of the car. I would have posted more photos but I cut the crap out of my thumb (to the bone!) and spent the afternoon in pain!
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
FINALLY someone else with this problem! They looked at me like I was crazy in my thread !
Excellent job with the writeup! I will be following in your footsteps. LEt me know how you resolve this problem
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
that's an amazing write up.
my doors aren't too bad, maybe someday i'll tackle this feat.
grats man.
grats man.
Car: Pair of 92 Z28s
i hate these doors in every way. I should be happy i dont have any problems yet with them cept the fact of the squeaky *** window upper moldings.
Now my gf's car could really use some restoration on.
Car: 91 Camaro RS
How bad out of alignment was your window before you started? Is it now leak free?
Car: 1989 Camaro RS
Engine: ZZ4 350
I washed the car yesterday and it was indeed leak free! In doing this I also cleaned and lubricated all of the weatherstripping with silicone brakes grease which helps keep it sealing and spongy.
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
theres also a sticky on door rattles that has additional info.
and search for my thread on lock restoration. while you have the door completely apart, if youre auto locks are 'sticky', it would be a good time to fix them.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
So that's how you adjust the windows. I'm so glad you posted this man, I just got the car back from the paint booth and I need to adjust the new window.
If I could rate the thread, you'd have 5 star from me.
What did you end up doing about the cracked mounting points, and would you mind snapping some pictures?
Car: 1989 Camaro RS
Engine: ZZ4 350
Ya, when I first discovered that problem on my doors, nobody else had heard of it either. My doors came off of an 89 also.
Car: 1989 Camaro RS
Engine: ZZ4 350
Originally Posted by fenton06
I searched but couldn't find anything on the window return spring...links would be nice, or if you could explain it that would be fine. Maybe I am searching with the wrong terms?
Other than that, put some lubriplate on the spring, the pivot, and the gears and it will work fine.
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I just replaced the motor in my door 2 weekends ago, but I need to put in th eTDS hinge parts too.... I'm legally blind and I was wondering, how the hell am I gonna get my big hand (and head) in that corner to ground off those bolts (I have to see stuff close up)... As with you, removing the door is best... can I just open the door and remove the bolts, do I have to go in the inner fender?
Any info on removing the door woudl be great, thanks!
Rafael
Rafael
Car: 1989 Camaro RS
Engine: ZZ4 350
Rafael
Rafael
Car: 92 zo3 z28
Engine: LT1 w/lt4 hotcam kit
Transmission: stage 3 700r4
Axle/Gears: posi 3.42
Re: Complete door rehab/resto! I mean COMPLETE!
as far as the "sash roller" where did u get that from i havent been able to find one and mines broke and the wondow keeps popin out and wont roll up all the way?
Car: 1989 Camaro RS
Engine: ZZ4 350
I didn't need to replace mine as once they were cleaned-up with acetone they rolled freely without binding or slop. I would contact the dealer or look for them at Classic Industries. Over 2 years later and still no problems and the doors are still tight and rattle free. My car club members are amazed when they hear my doors close, it sounds like a Mercedes!
Car: 1989 Camaro RS
Engine: ZZ4 350
People are still writing me about this 2 years later. How do I submit this for a "sticky"???
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Did you have any problems with the spring in the door hinge?
Does it need to be clamped or is it fairly easy to remove and put in place?
I have heard of a tool to remove/replace it but is it really necessary?
I'm looking to do the complete door refurb next month and want to make sure i have all the parts.
Also did you previously have any problems with smudge marks on the windows when you wind them up?
My guess is its from some kind of guide or rubber bump that has deteriorated and turned too soft, if so did you replace yours?
P.S. Awesome guide :P
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
how do you fix ttop rattle ?
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Depends. What have you done so far? The best cure I did for my car was install subframe connectors. T-top rattle is now minimal.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I took the plastic cover off of mine and discovered that all of the factory foam that runs between the ttop and the cover had gotten squished flat and half-deteriorated over the years. I added adhesive-backed felt to some 3m foam adhesive patches, cut them to size and placed them where the factory foam should have been. The difference in noise is much, much, better but I still get an occaisonal rattle from my passenger side, so I will have to take it back apart and maybe add some more felt.
Terrell351
Jun 13, 2021 01:13 PM
