Power locks don't work!
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
You can hear the solenoid turning and the lock moves a little but not enough. Is this a common thing? What do I need to fix it? Seems like (without removing the door trim) that a piece has worn down, must be like a little cam.
Any ideas?
Any ideas?
Hi ZZ42Fast
This happened to my firebird about 6 months ago. What I did was to lubricate all the moving parts of the lock mechanism. I also needed to remove the door trim. I used WD40 which worked ok, but when I posted about this people recommended that I use lithium grease.
See ya
89FirebirdUK
See ya
89FirebirdUK
what i find works best is to first liberally apply wd40 to the latch assembly, so much so that a stream of wd40 flows out of the door drain holes at the bottom of the door shell. then later apply white lithium grease.
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Mine do this too, but it's a real pita removing those damn door covers.
Last time I did mine I just used WD40 but after a while it started sticking again. Next time I'm freeing it up with WD40 and then smearing lithium grease over it. Do your windows stick too? Mine did. Bloody door panel off for those irritations too!!!
89FirebirdUK,
Where abouts in the UK are you?
Regards
Robert
89FirebirdUK,
Regards
Robert
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hi Robert, I forgot you were RMK! How you doin'? How's the car going? Make sure you make it to the Mopar Euronationals this July!!
RMK
How you doing ? I'm in Surrey, near Gatwick Airport. Where abouts are you ?
While I had the door panel off I also sprayed the window mechanism too. Like I said I used WD40 and it lasted so far !
89FirebirdUK (Geoff)
1992 Trans Am
May 10, 2023 07:19 PM
