sun visor mount question
Old Apr 27, 2002 | 06:49 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
91 bird..........my passenger side sun visor keeps fallin down by itself, highly annoying......so i figured id just tighten the screw that holds the visor onto the post, this usually works....no dice...so i took it all apart and the post and the mount are all one piece and the post is lose as hell in the mount...any way to fix this or is a new mount in order? i cant see anyway to tighten it...the posts just spins freely
Old Apr 27, 2002 | 07:24 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
If you take the 3 screws out and take out the whole mounting assembly, you will see (hopefully) a nut that you can tighten down on the spring around the post. There's a change the nut came off and is somewhere on top of your headliner.
:hail:IROC-Z
Old Apr 27, 2002 | 08:15 PM
uk89camaro's Avatar
I have just replaced a visor on my '89 RS, and have had a similar problem, cured as you say by tightening up the screw on the shaft). Can't see that tightening up the bolt in the main assembly will help, as you can pull the visor right off the shaft no matter how tight the bolt in the main housing is. You really have two options (1. cheap and not noticed, or 2. Buy an OEM replacement inc. all mounting parts). I'd go for the cheap option of :
a) Try a different grub screw.
b) Change the roof mount assembly (and/or) change the shaft, if the shaft is worn.
c) Pack out the shaft where it is hidden in the visor.
Old Apr 27, 2002 | 09:55 PM
wasp's Avatar
yeah i took it off, theres a spring with a washer on top of it and a hole in the center of that, no nut.....i thought there may be something at the base of that hole that would tighten the post but there isnt, whats the point of the spring?
Old Apr 27, 2002 | 10:11 PM
uk89camaro's Avatar
As far as I can tell, the spring in the mount is to allow the visor to swing (and stay) out towards to side window. The movement of the visor (in your face) is entirely dependant on that grub screw. Just pull off the visor and wind some tape on the shaft. Crude, I know, but it'll work.
Paul
Old Apr 27, 2002 | 10:14 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Whatever your car has(d) to tighten the post...nut or screw...has come loose and fallen out. I redid my headliner and greased the sunvisor mounts and then screwed the scew (or nut) down tight on the spring, so I know how it should work. If your other one is not loose, take it out and look at it and you will see what I'm talking about.
:hail:IROC-Z
Old Apr 27, 2002 | 10:18 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Re: sun visor mount question
Originally posted by wasp
91 bird..........so I took it all apart and the post and the mount are all one piece and the post is lose as hell in the mount...any way to fix this or is a new mount in order? i cant see anyway to tighten it...the posts just spins freely
This is the problem I am addressing. The grub screw IS for keeping the visor from swinging down. The one I'm talking about is for tightening the post in the mounting plate.
:hail:IROC-Z
Old Apr 28, 2002 | 12:06 PM
wasp's Avatar
mmm welp ill look in the hole in the liner but it looks like ill have to buy a new mount cuz im not ripping the liner out to look for no screw or nut.....also...wrapping the post with tape wouldnt help because the visor and post move as one, the post is loose inside the mount.....
Old Apr 28, 2002 | 05:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I experienced a similiar problem. I replaced the mount and all was cured.
JamesC
Old Apr 29, 2002 | 01:40 PM
wasp's Avatar
$25 for a sun visor mount
Old Jul 24, 2003 | 06:26 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
All I did was put superglue on the shaft and tape on the shaft where the screw meets it, its working so far.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
