TA fog lights.....
Old Apr 29, 2002 | 12:11 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
TA fog lights.....
The fog lights on my GTA aren't flush with the bumper/gfx. They were like this when i bought the car. The bumper seems to be "higher" than the fog lights and the fog lights are sitting a little bit below the bottom section of the bumper (partially blocked). It looks like ***. Is there any way at all to reposition the fog lamps higher so they sit flush with the holes in the bumper?
Old Apr 29, 2002 | 08:43 AM
Kaps's Avatar
Look on the top of the lights, there should be a torx head screw right in the middle on the top of the lights, loosen up, re-position and then tighten it, It might be a pain cause when you adjust it to be level, the bolt is actually above the lip in the nose. You might have to unscrew the two that retain the lights onthe side, I did mine this weekend but those screws where allready out cause the bulbs blew. Hope it helps...
1992Z28!
Nov 19, 2015 07:33 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
sbrandon
Sep 9, 2015 07:31 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
