parking lamp higher than other, hmm
Old Apr 29, 2002 | 09:07 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok, i was looking around underneath the 84 Z because my pass side turn signal assembly is up higher than the driver side one, and there is a large raised up bump in the headlamp opening where its painted black, like the frame rail or something is pushing up against it from underneath like the front nose is sagging on that side or something, but doesnt look like it sagging, body lines look fine everywhere
whats up with that ? fix it somehow ?i dont like the big bulge in my headlamp opening area
also on the 82 T/A the rear hatch sticjs back past the quarter panel only on the driver side and all the body lines look fine also, posssibly a hair closer to the driver side quarter than the pass side one though, forgot now
thanks for any info or ideas or fixes info
Old Apr 29, 2002 | 09:44 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
My '86 T/A has the same problem on the rear hatch.
It hangs over the end by about 1/2 to 3/4 of an inch. I can't figure out how to move it up.
The bolt holes on the inside didn't appear to have any verticle adjustment width to them, just bolt holes. I want to take the top completely off when I redo the window tint and will probably tackle it then. Any ideas?
Old May 9, 2002 | 01:03 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ttt
Old May 9, 2002 | 10:57 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My hatch also has the same problem; hangs over the taillights on the passenger side by 1/2 inch. I think it's because that's the side the car was hit on. (It was totalled, and then repaired by a body shop, and then they sold it to me.) I'm not letting it bother me; if someone notices it, that means they're too damn close to my car, and they better back the hell up before I get to them! When I did my bodywork to the whole car (5 years ago), I re-did that area, and sure enough, the paint under my paint was red, and the paint inside the rear wheelwell (under the undercoating) was red. The panel behind the taillights was red. Apparently, a red Firebird donated it's quarter section to my car.
Old May 9, 2002 | 01:17 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
interesting,,,, hmmmm i see that the 84 Z has the same deal, but not so much as the 82 SE. hmmm. stil curious about the bottom of the front headlamp pocket area having a pushed up bulge from something pressing from up underneath it,,. bumper shock flange, or something ??
thanks
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
