rocker ground effect bracket anyone?
Old May 9, 2002 | 07:15 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i need a bracket for the rocker ground effect, it goes on the rear of it behind the door and in front of the rear wheel it mounts to the ground effect with 2 screws then through the body near the seat, anyone know what i'm talking about or where i can get one?
Old May 9, 2002 | 09:42 PM
orange rocket's Avatar
Are you talking about the "hook" on the gfx or the studs on the body? If it is the gfx piece I have an extra seeing as my NOS one came with a new one
Old May 9, 2002 | 10:13 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
it is a metal bracket about 21/2-3" long and its mounted to the ground effect with 2 screws and a stud hangs out of it that goes through the body, i knew i shoulda took a pic of my other one when i had it off, it has to be the 85-90 style ground effect to have it, earlier ones used those round hook clips
Old May 10, 2002 | 05:48 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's the Camaro illistrated parts catalog, all the numbers are GM part numbers.
http://www.deadbird.org/diags-cam/index.htm
Old May 10, 2002 | 09:37 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
John THANK YOU very much!
Old May 12, 2002 | 03:14 PM
Spdfrk1990's Avatar
i know what peice your talking about look at a junk yard. They might even let u have it cause most of the ground effects at junk yards are broken ne way,
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
