Cupholders
Old May 10, 2002 | 07:12 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Cupholders
I got a set of cupholdsers that came in trans ams i guess the ones that go in the side of the door. How do i go about mounting them do i jsut screw them in or is there like spots they are made to go into??? Second i need to repaint them they r 2 different shades of gray what kind of paint do you recomend i use.
Old May 11, 2002 | 10:21 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If your car is an 89 or newer there will be square shaped holes in the inner door skin behind the door trim panel. Get some of the plastic inserts that fit these holes. They are in the HELP section of the auto parts store labeled "License Plate mounting kit". Push the inserts into the holes then screw a screw into them and reinstall the door trim. Pound on the door trim with a hammer in those locations. It will create an indentation where the holes should go. Then punch through with an awl. If your car is older you will have to line the door pocket up with the inner door panel and drill the holes. In that case just use regular sheet metal screws to attach it or drill a larger hole, slip in J-clips and screw into those. The plastic can be painted with SEM Color Coat. It is a plastic paint made for flexible or rigid plastic and sold in good paint stores. Good luck, Lon.
91TealRS
May 12, 2002 11:01 PM
IROC-ZWV
Apr 1, 2002 04:02 PM
rjmcgee
Dec 13, 2001 10:27 AM
25th anniversarry RS
Feb 25, 2001 09:38 PM
