leak
Car: 1989 Camaro
Engine: 383
leak
I have a leak in the passenger side. Its right where the floor sinks in the most. It has a puddle of water with a greenish tint to it. However it only leaks when it pours a side. I feel all around the wet spot and its not wet anywhere but where the puddle is. Any suggestions??
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
its simple, your heater core is leaking, you have to replace, get a haynes manual to help you , but if you have to drive it untill you fix it, you can plug off the two hoses, one from you center manifols, the other from your water pump, going to the fire wall. however you wont have heat while these are plugged,
