why doesn't this fit
Old May 13, 2002 | 06:47 AM
salty's Avatar
84 car, 92 hood-- why doesn't it match.
Old May 13, 2002 | 07:21 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My guess is that either your car or the 92 had collision work and wasn't put back where it belongs.
Old May 13, 2002 | 05:05 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Nosecones were differant in '84 compared to a '92 one. in fact there was 4 differant nosecones available depending on what year/options.
Old May 13, 2002 | 06:34 PM
salty's Avatar
Thanks john,
Old May 13, 2002 | 07:18 PM
Jim85IROC's Avatar
The nosecones were different but the hoods should interchange universally and fit fine.
Old May 14, 2002 | 12:37 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ya, maybe your hood is out of alignment???
Old May 14, 2002 | 02:11 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Well to me it looks like it lines up with the outer edge of the nose, so if you moved it forward to line up with the middle of the nose, then it wouldnt line up with the outer edges of the nose. I'm thinking the car has been smacked, like said before. The hoods should swap w/no problem.
Old May 14, 2002 | 11:30 AM
Black85TransAm's Avatar
different front end?
Old May 14, 2002 | 04:26 PM
383 rocket bird's Avatar
You've just got to look at everyting carefully and you will find your answer. On my 89 Gta there was about a .5 inch gap where the fender sat out farther than the leading edge of the door. Turns out that when the previous owner had work done on the car the shop jacked it up right where the fender bolts to the underside of the car and bent the mounting flange outwards, pushing the fender out.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
theurge
Aug 21, 2015 12:46 PM
