Fender alignment
Old Jun 21, 2002 | 01:54 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Fender alignment
My fenders are out of alignment I think. They match up at the front where it meets the bumper but where it meets the door the fenders have about a centermeter gap out from the doors. The doors also match the rest of the body, so I don't know. Any ideas?
Old Jun 23, 2002 | 07:17 PM
original's Avatar
Has the car ever been wrecked or repainted? If so someone could have put the fenders on out of allignment. I've had to do this on quite a few cars. First, make sure the doors are alligned well with the body. If so like you said, then loosen the fender bolts and move the fender around and retighten it, in it's correct position. be sure not to push the fender to close to the hood,or it will screw up everything. I've had to lift from the bottom of the fender by prying (VERY gently) with a block of wood and a 2X4 for leverage.Good luck.
Old Jun 23, 2002 | 07:21 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
the fenders bulge out further than the doors? a lot of thirdgens have that problem. Usually from some dumbass jacking the car up or putting it on a lift improperly, and messing up the bottom of the fender.
Old Jun 23, 2002 | 11:57 PM
Camrs89's Avatar
Yeah, the fenders bulge out a tiny bit, do I just move the fenders like original said? Thanks
Old Jun 24, 2002 | 06:50 AM
TheWraith's Avatar
Engine: 355
you're gonna have to pull the gfx off from under the door, and see what's going on down there on the bottom of the fender behind the wheel. It's not an alignment issue most likely, it's something bent on the bottom of the fender. You may or may not be able to fix the problem yourself.
Old Jun 27, 2002 | 10:21 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I had the same problem when i bought my bird, the kid i bought it from used to jack it up right under the fender.
Both fenders stuck out like 2 inches, when me and my dad painted it, we just pulled of the ground effects and grabbed the twisted part of the fender(you will see why it sticks out when you slide underneath the car) and pulled it down with a vise grip. Now it is perfect. No big problem.
Old Jun 27, 2002 | 11:16 PM
Camrs89's Avatar
Ok, thanks guys I will check it out. I noticed though that the drivers side fender is a replacement fender. Dont know if that has anything to do with that side or not.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
meeklay812
Oct 1, 2015 03:46 PM
