dirty seats, what to use to clean???
Old Jun 24, 2002 | 02:19 AM
90Iroc-Zee's Avatar
okay what should i use 2 clean my seats??? a tiny bit of bleach/soap water then some regular water when im done??? vacuum afterwards??? im gonna clean the engine bay tommorow hopefully start on the interior also, just wondering i gotta keep it looking good ya know. an ytips or anythign would be awesome,thx.
Old Jun 24, 2002 | 03:22 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Semi- soak the seats in water, put on a coat of Tuff Stuff cleaner ( or your favorite foam cleaner), let it sit for a while, then use either a "wet dry vac" or " the absorber " to ( wet dry is recommended) . Then from their, take an AOL CD and scrape over the semi wet surface and the water should come out with each scrape. All of this is assuming that you have taken your seats out.
works for me.
Old Jun 24, 2002 | 02:13 PM
90Iroc-Zee's Avatar
cool thx, dont know about taking the seats off but ill do what you said best i can...woot no more dirty spots then :-P
Old Jun 24, 2002 | 02:43 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Ditto on Tuff Stuff... that stuff works good.
Old Jun 24, 2002 | 10:39 PM
RiceBurner's Avatar
Get some Rug Doctor solvent and a brush. Scrub your seats, then let it dry for 10 mintues. Then take a wet/dry vac and suck it up.
Bret
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 9, 2015 10:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
mrdevontay
Sep 2, 2015 08:04 PM
