87 IROC with an 87 'Bird 305?
Old Jun 24, 2002 | 09:35 AM
BrokenAngel's Avatar
Front Fender problems
I'm not sure if its the fender or not, but ever since the fender has been removed then put back on, the hood doesn't open or close properly... It seems to be pulled (or pushed) towards the side opposite the new fender... Any ideas?
Old Jun 24, 2002 | 09:45 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
A better place to post this is in the ENgines/Tech forum.
You will need to do a lot of things, not least of which is I am pretty sure the transmission bell housing for the 6 won't mate to the 8. Then there is all the wiring harness stuff, you are going from an MPFI to what? TPI? Carb? You'll need to figure what to do with the ECM and PROM chips. Someone around here may have made up a swap guide.
Old Jun 24, 2002 | 09:47 AM
Oops
I know, and I meant to... just posted the wrong one up... Oops.
colton_carlson
Mar 8, 2019 12:21 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Catcher55
Aug 15, 2015 07:08 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
