t-top suggestions
Old Jul 7, 2002 | 04:03 PM
redbird6815's Avatar
t-top suggestions
my car didnt come factory with t-tops and i want them really bad i think it makes the car so does anyone have an estimate onthem and if u dont think its a good idea people have told me to get a sunroof? i thought that would look stupid in firebird so tell me what you guyz think thanx
Old Jul 7, 2002 | 04:09 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
imho i think its a bad decision to put ttops in aftermarket...they leak from factory let alone aftermarket..but it is your car just be ready to have water leaking into your car every and anytime it rains..and when it pours...well GET FLOOD INSURANCE!! cuz its a biggie..
but it is your car like i said b4 so you should do what you think is good..and as for cost..i think its gonna be expensive...put at least $300 more on top of what you would be charged for a sunroof!!
iroc2nv
Old Jul 7, 2002 | 10:21 PM
SX Stinger's Avatar
Car: 84 Z28 "Holly" (SOLD)
Engine: Carbed 305
Transmission: TH350
I agree with iroc2nv, I have factory T-Tops on my Z28 and last month I was finally able to get them to quit leaking. In my opinion T-Tops do make the car I mean they just look good and you get a similar effect to the convertible without the top maintanance. If you want them bad enough you will learn to live with the leak but its the price to do it that your gonna hate. If you want it raelly bad go for it.
Drew
Old Jul 7, 2002 | 10:47 PM
BikertrashDude's Avatar
i think it would be very $$$ to do T-tops because you just don't take a hacksaw to the roof and cut out two panels.
that center bar is renforced metal so the car will not "bend"
oh t-tops don't leak its old rubber that leaks.
biker
Old Jul 7, 2002 | 11:22 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Cars & Concepts on longer makes the kit.
Back in 1990 they were $2500 installed.
My suggestion is buy a car with one. And if you still have you heart still set on changing it. Junk yard is the place for you.
I've had both: ASC - 84 Daytona TA and C&C - 90 Firebird tops.
Good luck
Old Jul 8, 2002 | 11:44 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
post after post people just say they leak, but ive never had any problems
Old Jul 8, 2002 | 12:24 PM
MdFormula350's Avatar
I fixed my leaks, they did leak slowly, but now no more leaks at all some adjusting and silicone fixed everything. And there is only a slight bit of rust from when they were leaking along the drivers side on the underbody. Nothing alittle body shop cant fix when installing my subframe connectors.
Old Jul 8, 2002 | 12:29 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
https://www.thirdgen.org/techbb2/sho...threadid=68825
https://www.thirdgen.org/techbb2/sho...threadid=68067
https://www.thirdgen.org/techbb2/sho...threadid=67292
https://www.thirdgen.org/techbb2/sho...threadid=66633
:hail:
Old Jul 27, 2002 | 01:22 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
http://www.markscustomkits.com/T-top_Conversion.html
Level one
1500 glass panels not included, no finish work
400 glass panels(I would just get junkyard ones)
You will need a new windshild also
Level two
3000, including install of the seals windshield and panels
Weld seams still need to be ground down and feathered, by body shop before painting.
Level 3
7,000
car painted and ready to roll
Shipping now that is the question.
Its expensive since you can get a good t-top car for 3k anyways and fix it up.
btw they do this to make custiom, knightrider cars, but I'm sure they want mind just installing the t-tops.
Old Jul 27, 2002 | 03:57 PM
dbarker02's Avatar
biker...
yes the older the rubber the more they leak... but the tops themselves can leak if they dont set on the rubber propperly.. ie body flex throws ttops outa wack just enough to give you a bath in your car... aftermarket ttops are bad about that because when u hack the roof up,u get SOME body flex...
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
