T Top Storage and the bag
Old Jul 14, 2002 | 09:34 PM
igotslicksNchix's Avatar
hey guys, i have no bag for my t tops, never had one. when and if i get the bag,(can i have pix of the bag anyone????) where does it go to be stored??? it scares me to think where the previous owner left the t's when he went somewhere. How hard do u think it would be to make or have made one of these bags???
Old Jul 14, 2002 | 09:57 PM
mudaholic's Avatar
bags cost around 50 bucks on ebay, you should have 2 mounting brackets over your gas tank, and two more in the rear of the car protruding from the trim panel.. the bag has 4 clips, they just latch onto these brackets...
Old Jul 15, 2002 | 12:27 AM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
**** BAGS, I have invented the T-TOP Rack prototype >>
Going to be building a better abs plastic version that matches the color carpet and rear panels and blends right in within the next few weeks and be selling them.
Old Jul 15, 2002 | 08:00 AM
BikertrashDude's Avatar
my buddy got some plastic ones in his 86 TA that do the same thing as yours mike.
he also has a bag too.
i don't know how anyone would lose a bag or leave the T-tops behind.
i have been caught out on the road when i see some drops on the windsheild and i pull over put the tops on and two miles later.
its a summer storm...........
biker
Old Jul 15, 2002 | 08:05 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Mike- How much will you be selling the finished product for? I'd consider buying one if the price was right.
Old Jul 15, 2002 | 06:33 PM
Chris Luongo's Avatar
Hey Mike,
I've been thinking of a similar upright-storage thing like you have going on---the bag is annoying to mess with.
It appeared to me that the well of the hatch simply wasn't wide enough to accomodate the tops---I was thinking to cut out the "shelf" on one side of the well and fabricate a larger version---there is still enough room between the frame rails to do it.
Or am I missing out on something? In your picture, it looks as if the tops are sticking up too far to close the hatch lid.
Old Jul 15, 2002 | 08:01 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
I hate using my bag. I've had the tops sitting exactly like how Mike has his sitting in the Iroc.
There should be plenty of clearance for the tops, as the handle area could tuck up onto the center hump of the hatch area.
Old Jul 16, 2002 | 12:29 AM
HrdRockA4305's Avatar
Damn straight man the bag sucks!
That was one of my summer projects that kinda never got started. I hate using the bag too, I set mine kinda like that with a couple pieces of foam between them. I meant to make a rack, but kinda never did. I like how you did that. I'm thinking on trying one that uses metal pipes with that round foam insulation around them for padding. We'll see how it turns out. If I can't make anything decent and I like the ABS one you say you're gonna work on, I might be game for one if I can justify spending $$ on it. It'd be trick though, nobody else has got one.
Old Jul 16, 2002 | 07:39 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
I don't think the bag is that bad. My t-tops are in their bag right now (safely locked away in the garage for the night of course). In fact my only complaint is a tear in mine which I'll probably stitch back together if they ever let me take some time off work...
Old Jul 16, 2002 | 08:08 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My 4th gen has a rack like that.. I wonder if they would hold a set of 3rd gen tops tightly enough.
-- Joe
Old Jul 16, 2002 | 09:36 PM
i think i'm going to work on a rack that would put the t tops on each side of the car, might look a bit neater that way.guess i'll just experiment.
Old Jul 16, 2002 | 10:08 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
4th gen t-tops are quite different, I tried mine in my buddies and didnt see an easy way to make it work without major conversions. Might as well build a custon holder like he did. Jsut be safe and keep your t-tops locked down (however you do it), nothing worse then a t-top flying up and smacking your head at a sudden stop or rear end colision. I imagine it could be deadly.
Old Jul 16, 2002 | 10:10 PM
4th gens t-tops are smaller than ours, I have been studying them, all OF OUR T-TOPS WILL FIT UPRIGHT IN THE HATCH, just sit them in there, I was doing it like that with a blanket between them, but i wanted somethign just to be safe.
Hopefully I can make a mod and create somethign outta plastic with foma incerts to protact the glass and sell for around 100 -150 bucks. Sounds reasonable to me. And it will just sitt in the bottom of the well.
Don't believe me, go shove them in the well, they will fit just fine back there.
Old Jul 16, 2002 | 10:11 PM
T-tops won't fly out either, there is not enough clearance when the hatch is closed for them to fly out or even be lifted out from the passnager set.
Old Jul 16, 2002 | 10:21 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
This is very true about the tops fitting in the back well. Mine fit quite well back there.
I make due with just bracing mine in place. I might make some straps using the factory hardware to hold mine in place.
I just don't like the bag, my velcro one sucks.
Old Jul 16, 2002 | 11:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I always thought the backseat was designed for the tops since normal people can't fit back there
Old Jul 17, 2002 | 12:25 AM
Yep. They fit fine, been putting them there for over a year and have never even came close to having any trouble. They can't fly out, they don't have room. I think I'm gonna hit Lowe's tomorrow for materials/ideas. Well maybe just ideas, I'm kinda broke right now until next week.
Old Jul 17, 2002 | 08:10 AM
i like the ideas i've heard think i'm gonna try sometin out like this. Sorry pennylesz, 100 bucks might be fair but i wouldn't pay it when i could make it myself, but i think you do have a good product on your hands. good luck with all of your t top endeavours.
Old Jul 17, 2002 | 09:15 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I would buy one of your racks if you start to make and sell them. Keep us posted. I have had both bags, Velcro or Zipper. The Zipper is just fine. the Velcro sucks .
Old Jul 17, 2002 | 03:51 PM
89Irocz23's Avatar
a friend of mine has a 2002 camaro v6. His hatch area will the t tops go is kinda cool. They sit in a rack kinda thing, but the latch it self locks them in. The pins or whatever they are slide into a hole and lock in just like they do on the roof. Now if I could make something like that for my Iroc it would be sweet.
Old Jul 17, 2002 | 06:01 PM
I'm working on it!
Old Jul 18, 2002 | 08:53 AM
i'm soooooooooooooooo freakin happy! i was digging through my parts car, and in the hatch, under plastic tarps and blankets, THERE it sat. A T top bag. There for my taking. The parts car was given to me for free, so i just saved 50 bucks right there from it, not to mention the joy of ripping the car apart and keepin what i like anyone wanna buy parts? lol.
Old Jul 18, 2002 | 04:21 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
what u got
Old Jul 18, 2002 | 05:26 PM
well, theres misc. parts, i'm pretty sure it's a 2.8 under the hood, questionable if it runs, and a cargocover, and a few other items, i prefer just for people to ask if i have it, cause i'm not exactly sure whats in there
Old Jul 19, 2002 | 11:30 AM
92GTA's Avatar
Here is a good pic:
What could be better? The bag even has a felt insert in the middle to go between the T-Tops to protect them....
Old Jul 19, 2002 | 08:21 PM
Well, the things I don't like about the bag are:
-Takes a long time to get them in and out compared to the rack style holder
-Straps that you have to mess with
-Big long zipper you gotta mess with
-Having to bend/reach in the far forward makes my knees hurt, and if you bump the car and its a bit dusty you get crap all over your clothes, bad thing if you're on your way into work.
When I first got the car, the first thing I said about the bag was "Now really, couldn't GM have come up with something better than a freakin bag strapped down to the hatch floor?"
Old Jul 19, 2002 | 08:26 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
well on the zippers i never zip mine up, it's just a waste of time, i drive around with the tops off all the time and the zippers dont need to be zipped, i think the bag is more protective then just laying them in the backseat.
Old Jul 19, 2002 | 08:49 PM
92GTA's Avatar
HrdRock, your're looking at it from totally the wrong point of view. It's should be not what is more convienent for you but what protects the T-Tops the best. I don't have a hard time at all using the bag, I just take my time to make sure that the tops are in there straight and it will zip right up everytime. I'd take the bag ANY day over the stupid slots on the floor, I think all the 4th gen's should have stuck with the bag. I mean, they just plain move around too much in the slots and they can bang against each other too easily.....
Old Jul 19, 2002 | 09:23 PM
some people have no patience
Old Jul 20, 2002 | 09:24 AM
if your bag is already hooked on to the top hooks and it is already open then it takes you what?? 30 seconds to put the tops in the bags??? sorry i rather do that then lay them loose. what happens if you have to break hard or something and the tops go flying and break and you end up with the inside full of glass??
it's too easy to put the tops in the bags.
think about people that had manual convets' that they had to crank down and them cover the retracted top with a cloth top by using buttons. that is a pain in the butt.
biker
Old Jul 20, 2002 | 01:03 PM
Haha nope, I don't have much patience.
I've been doing the "tops in the cargo well" thing for more than a year now. They don't get beat up at all, and they always stay in place. The hatch would stop them from flying out under hard breaking... trust me if it were possible for this to happen it would have by now. I have stuff padding them, and even if by some remote chance something happens to them, like I drop one or something, I have a spare set anyway.
So, it protects them adequately and is more convenient for me. They never bang up against each other or move around, not for me anyway. So thats what I do.
Old Jul 20, 2002 | 01:29 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
mike, thats a great mod! Really good idea too! I didn't have abag either when i got the car, and didn't know the difference in them when i bought one on ebay. I got one from an 82 that was velcro and is reall tight around the t-tops and takes me like 3 minutes to get them in there and it snags all the time. Really annoying, but better than putting them in the back seat
Old Jul 20, 2002 | 11:56 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
hey if u guys dont want ur bags sell them or give them to me cuz i want a bag
Old Jul 21, 2002 | 12:06 AM
Update: I was struck by inspiration today, went to Lowe's, and built a "rack" for the tops outa PVC pipe and foam insulation. I'll take a pic or 2 tomorrow. Its kinda neat, I mean its not killer, but it works extremely well. Cost 7 bucks and some change to make. I'll tell ya how I did it when I post pics.
Old Jul 21, 2002 | 09:26 PM
No Offense, you're stupid as crap. The 4th gen t-tops don't move at all. They are held very tightly in place.
Mine are also helpd very tightly in place in the rack i mad and they dont' bump together or anythign. Proper spacing and its a tight fit so it is held firmly in place.
Old Mar 3, 2004 | 09:36 PM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
I bought a set of the 4th gen holders off ebay and I think I can get our tops to fit witha bit of Dremel work. Our t-tops are about 1-3/4" widewr than theirs so all you would really need to do is dremel out the area to make it so that the hatch fits in a slot cut out on the other end of the holder and we also would need to Dremel out a bit at the bottom so that they would lock in place.
Old Mar 4, 2004 | 01:01 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
my car came with the original t top bag(zipper) and its awsome never had a problem
Old Mar 5, 2004 | 03:56 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
I like the bag for several reasons;
- with the tops upright in the well, my vinyl hatch cover doesn't fit
- I have subs in the storage well
- the straps on the bag hold the tops still when driving "spirited"
- I think it looks nice, just putting them in the hatch looks sloppy to me
- The bag seems to protect them really well
Just my opinion...
Old Mar 5, 2004 | 09:57 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Just my opinion...
You wouldn't happen to have a pic of your subs AND your t-tops in the hatch at the same time would you?
I am trying to decide if I want to build a box for the back or just sell the DVC's sitting in my garage.
Old Mar 5, 2004 | 10:46 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
No, I don't, and it's in storage right now, and I wont be able to get to it untill may . However, my box comes up flush with the back of the hatch plastic (where the motor is), and angles down to be flush with the rear deck. I just put my tops in the bag, and turn the bag around (the trim part with the key on both tops tward the front of the car), and it fits perfectly. I also relocated the strap brackets from the back wall of the cargo well to the sub box, so I have something to strap it to. It works pretty good for me. If you still want a pic, I can get one when I take it out in May.
Old Mar 5, 2004 | 03:28 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
Awesome, I may take you up on that.
Old Mar 5, 2004 | 09:13 PM
  #42
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
humm crazy that u brought this up, im going to start making my rack tomorrow since my zipper broke.
Old Mar 6, 2004 | 12:04 AM
  #43
BigMike1610's Avatar
Engine: 305 tbi=LO3
Transmission: Automatic
i did upright storage a year ago :lala: your plans look a bit better though
Old Mar 6, 2004 | 06:16 PM
  #44
87 B4Z TPI 5Spd's Avatar
I test drove a 91 V6 Firebird last summer. The tops fit into a plastic slotted holder at the bottom of the well. I thought it was factory, and never gave it a second look. Sure looked stock. I'm guessing now it was an aftermarket addition. Has anyone else ever encountered a stock-looking holder in a late 3rd gen Firebird well?
Old Mar 7, 2004 | 08:46 PM
  #45
I would love to find out where they came from, it might have been one of those "T-Savers" some dude used to make....someone has got to have one somewhere
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
