For Firebird owners needing new headlight gears....
Old Jul 30, 2002 | 08:56 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Just an FYI,
Corvette Central (www.corvettecentral.com) and Ecklers Corvette Parts (www.ecklers.com) sell bronze headlight replacement gears. Price is around $59 each and also includes new bushings that are much better than what GM originally used.
If your headlight gears are worn, I recommend picking up the ne gears.
They do also carry plastic replacement gears for a lower price.
Old Jul 30, 2002 | 10:57 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Yea, they've been selling them for a long time, but I'm sure not many members are willing to shell out $120 just for those gears. You can get two new complete actuators (motors) with a lifetime warranty for that price. It's also dirt cheap to fix the ones we have. But thanks anyway. I'm sure a lot of members were unaware of Eckler's. Dang GM should have just put good bushings in there in the first place instead of that blasted gel junk.
Old Jul 31, 2002 | 09:40 AM
Nasty_Bird_'90's Avatar
dang it, is that why my drivers side motor will spin but the light wont go up? i had a feeling it was in the gearbox, but i havent taken ut apart yet. ihave very bright foglights.
Old Jul 31, 2002 | 09:54 AM
MdFormula350's Avatar
hey nastybird, Z28z (the one with the white camaro with nitrious) and i were talking about that at the show on Saturday. He said something about some ford part for windows can be used to fix our firebird headlights. He said its a direct fit and fixes the problem with the headlights being stuck and/or not coming up or down!
i would pm him and see if he can hook you up.
Old Jul 31, 2002 | 11:26 AM
Car: Yes...
Last time I checked, the complete actuator assembly was $140 for each side. And that was a deal thru Dal.
I did the "rotate the gear" fix which worked for a while, but my headlights are acting up again. So, I dropped the $120 for the bronze gears. My headlights should be fixed for good now.
All you need are new bushings to insert in the gear. Corvette central sells those as well for $5 a set.
Old Jul 31, 2002 | 09:32 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I meant just the motors, not the whole assembly. I dunno, maybe the prices went up since I checked them; it has been quite a while. Having the hookup for that kind of thing rocks. Please keep us informed on how you like the gears. I will be getting a set eventually if they are all they are cracked up to be. Thanks.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Poncho92
Aug 7, 2015 08:15 PM
